Post by laardo on Jul 6, 2015 12:40:22 GMT -5
STARTER FINE BUT CAN NOT GIVE THE FULL POWER ENGINE STOPS WHEN I GIVE GAS... changed oil seals on both sides and new karborator but does still not working... any suggestions?
Post by 90GTVert on Jul 6, 2015 21:45:11 GMT -5
Welcome to the forum.
Is the stock air box in good original condition and installed?
Post by tiny on Jul 7, 2015 3:44:07 GMT -5
maybe a clog in fuel lines?
Post by laardo on Jul 7, 2015 5:18:50 GMT -5
air box is original and istalled 100% good... and we have cleaned all fuel system its only have 1700miles...andi have tjeck the piston and cylinder its looks great... im lost my mind :-D
Post by birdman on Jul 7, 2015 5:52:01 GMT -5
Is the main jet clogged? Where you from?
Post by laardo on Jul 8, 2015 5:28:03 GMT -5
Denmark... engine starts very easily and runs well at idle so when I give gas it runs unevenly and eventually die when I keep pressing the accelerator...
Post by 90GTVert on Jul 8, 2015 9:15:16 GMT -5
I'd clean the carb and check the main jet as birdman suggested. Could be clogged or partially clogged and blocking fuel supply beyond idle/low throttle.
Post by tiny on Jul 8, 2015 16:24:17 GMT -5
Sounds like a good Idea to me.
