Post by ryan_ott on Jul 20, 2015 8:55:08 GMT -5
If you pull the seat bucket the cdi should be bolted on right side frame rail facing the plastics, just in front of the starter relay.
Post by Jwhood on Jul 20, 2015 10:59:18 GMT -5
Its there didn't realize they were that small on the morini there lot bigger,also has the 1E40FM cylinder
Post by Jwhood on Jul 29, 2015 17:50:47 GMT -5
Pulled off head and cylinder it was a milky white substance so I looked at rings and cylinder all is good so I put it all back together,I'm leaning towards bad gas in the tank so I drained all the gas out the tank and gonna clean it completely out tomorrow and put a manual petcock on and get rid of the regular petcock!!!
Post by derbiman on Jul 29, 2015 17:57:33 GMT -5
Glad to hear your top end is ok. Damn ethanol gas anyway.
Post by Jwhood on Jul 29, 2015 19:29:49 GMT -5
Yeah this thing is brand new I mean nice for a 9 year old scooter it only has 1300 miles on it,and the little tiny rubber pieces are still on the sidewalls of the tire,also its getting spark I checked that today also so if the fresh gas doesn't fix it I will trouble shoot more
Post by derbiman on Jul 29, 2015 21:42:37 GMT -5
I had to clean the whole fuel system on a friend's Eurostrada a few weeks ago. He had bad gas in his also. It was pretty simple and straight forward.
Post by Jwhood on Jul 29, 2015 23:18:08 GMT -5
Yeah p.o already had gas tank loose so its out ready to be cleaned
Post by derbiman on Jul 31, 2015 8:50:59 GMT -5
Any progress on your scooter?
Post by Jwhood on Jul 31, 2015 20:01:28 GMT -5
Got home late tonight gonna work on it tomorrow morning since I don't have to work this weekend I'll keep ya posted
Post by Jwhood on Aug 1, 2015 20:10:04 GMT -5
Still nothing it is right at trying too start but then dies,dumb question does it need a battery to start even with kick start lever,my morini doesn't need a battery too start the lights just won't work ?
Post by derbiman on Aug 1, 2015 21:23:29 GMT -5
I would think that it would be an a.c. fired cdi so it should not need a battery but I would not run it very long without a battery. It may burn up your charging system. Even if you use a dead battery for now,it is still better than no battery because the generated voltage is at least going into the dead battery and protecting your charging system from frying.
Post by derbiman on Aug 1, 2015 21:24:59 GMT -5
If you are still getting spark without a battery,it is a.c.fired.
Post by Jwhood on Aug 1, 2015 21:46:47 GMT -5
Yeah still getting spark without battery, I cleaned out tank with bb's today it was bad but got it cleaned out,also re-cleaned carb and also took out petcock and ran nipple off the end and manual shutoff valve,just don't understand why the thing won't turn over
Post by scooterpimp on Aug 2, 2015 8:12:00 GMT -5
I noticed it takes forever to start minarellis that have been sitting , without electric starter spinning engine over faster then kicker.
Post by Jwhood on Aug 2, 2015 13:54:20 GMT -5
I'm gonna go see if I can get a battery and try too get this thing ripping again
