Post by Jwhood on Jul 19, 2015 12:36:51 GMT -5
Just got one of these its my first ever minnerelli based scooters so there new me,I've cleaned the carb and gas tank and still will not start,it will try too start but won't stay running not even for 2 seconds,any idea on what the issue can be? Seller said he was having same issue he was not a scooter mechanic in any stretch of the imagination, oil tank has oil in it just don't understand why it won't turn over?Also where is the cdi located at I have all plastics off except the front by the light??
Post by 90GTVert on Jul 19, 2015 15:50:46 GMT -5
I'm not sure about the Yamati, but on my Triton which is the same body style the CDI was bolted to the frame on the right side just behind the seat/before the gas tank.
Compression?
Post by Jwhood on Jul 19, 2015 17:01:37 GMT -5
Yeah also thinking now that the person before the guy I bought it from ran it with no oil,I get a weird burnt smell on plug end that was on the scooter,I'm gonna take off the cylinder and see what's going on,also there is no cdi behind the seat,none what's so ever,I know I'm not going crazy!!
Post by TheAmishSasquatch on Jul 19, 2015 19:23:50 GMT -5
I had one, ran for 5kms, it sucked ass, didnt run right, had a cracked piston, sold it for $425 in '07
Post by oldgeek on Jul 19, 2015 19:32:38 GMT -5
Possibly the PO took the CDI off? The CDI should be on the right side of the frame under the panel.
Is the airbox still attached?
Post by scooterpimp on Jul 19, 2015 19:37:18 GMT -5
Burnt smells are never a good thing, keep us posted on that top end. At least parts are cheap & easy to find vs the morini makesure to bleed/prime oil pump if it was dry., if you have spark you got a cdi.lol.
Post by Jwhood on Jul 19, 2015 19:40:50 GMT -5
No previous owner took air box off,I'll look tomorrow again for cdi,it seems like it wants too start,Im leaning towards soft seize and blown rings!! I know it had too have one cause it wouldn't turn over at all just couldn't find it know where,and there big so how the heck can't I find it?Yeah the burnt smell isn't good,I'm gonna take the pump off and premix!!!
Post by derbiman on Jul 19, 2015 19:50:35 GMT -5
Maybe the cdi and coil are one unit.
Post by oldgeek on Jul 19, 2015 19:55:03 GMT -5
No previous owner took air box off,I'll look tomorrow again for cdi,it seems like it wants too start,Im leaning towards soft seize and blown rings!! I know it had too have one cause it wouldn't turn over at all just couldn't find it know where,and there big so how the heck can't I find it?Yeah the burnt smell isn't good,I'm gonna take the pump off and premix!!! It wont run much without the airbox. Find one, put it on and try again before you go to the trouble to tear the top end off.
Post by 2TDave on Jul 19, 2015 19:59:13 GMT -5
Have you tried putting your hand over the carb. Your getting too much air and lean w/o the air box. Some Yamati's have a different Mina then the norm. Makes them great for 90+ cc builds but you'll be pressed to find a 70. Take some pics and measurements of the cylinder when you pull it.
Post by Elektrey on Jul 19, 2015 20:00:33 GMT -5
When my cylinder seized I could smell something
Also the plug was "charred" if you will. light gray burnt color
Post by Jwhood on Jul 19, 2015 20:00:36 GMT -5
Yeah I tried with the air box on still no go,will do on the measurements!!yeah trey the plug had like a greyish milky color on it when I pulled it just thought it was from old gas sitting in cylinder for a long time!!
Post by 2TDave on Jul 19, 2015 20:04:49 GMT -5
My scoot is a Eurostrada RX8 but not a Yamati. What's the engine code by the shock?
Post by Elektrey on Jul 19, 2015 20:20:43 GMT -5
Yeah I tried with the air box on still no go,will do on the measurements!!yeah trey the plug had like a greyish milky color on it when I pulled it just thought it was from old gas sitting in cylinder for a long time!! probably seized then. I'd upload mine but I threw it away. It's kind of an ashy color. I imagine old gas sitting in the cylinder would actually evaporate out the exhaust, leaving just oil. I'd definitely be looking at a compression check
Post by Jwhood on Jul 19, 2015 20:27:10 GMT -5
My scoot is a Eurostrada RX8 but not a Yamati. What's the engine code by the shock? "1E40QMB-A,also says " Linhai..Yamaha on variator cover
