Post by silverspar1 on Oct 1, 2009 19:57:51 GMT -5
I'm a member of a Super 9 group on Yahoo. Yesterday I posted some pics of my scoot. This guy emailed me today and said that he knew who used to own my scooter (not the guy I bought it from but the original owner. The dude I bought it from only had it for a couple of months and really did'nt know much about scooters.) Anyway, he said that my scooter was in the database and everything that had been done to it would be listed there. Their was even a history of all the old posts the guy had listed. Here's what I found out.
> > 2004 Super9 S > > Airsal t6 73cc > > tecnigas rs70 pipe > > Delorto 19mm Carb Air/Fuel 1 and 1/4 turn out > > Needle Size W9 set at bottom position > > Jetted to 110 > > Unifilter Chrome > > NGK resistor plug cap,to fix eratic tachometer > > Malossi variator 6.5 rollers > > Motorio yellow torque spring > > red clutch springs > > Removed USA front signal stalks, Wired up the Euro ones. > > Fender eliminator kit custom. Removed center stand, Removed rear grab handle.
Post by 190mech on Oct 1, 2009 20:00:24 GMT -5
Cool to know your history,most of us just try to piece the scoot back together!
Post by silverspar1 on Oct 1, 2009 20:10:55 GMT -5
Cool to know your history,most of us just try to piece the scoot back together! Yeah I know I've been there and done that too.
Post by 90GTVert on Oct 1, 2009 20:25:20 GMT -5
Thanks for posting. I know folks were quite interested after hearing of the performance you're getting.
Post by silverspar1 on Oct 1, 2009 21:36:11 GMT -5
Thanks for posting. I know folks were quite interested after hearing of the performance you're getting. Just to add to that, my performance was'nt as good as I had initially thought. I actually got to talk to the guy on the phone and he said that the speedometer was a full 8 mph off. So my 0 to 50 time took a big hit. However GPS top speed on a calm non windy day is around 67 mph. Not as impressive as I first thought but it does sound alot more realistic.
Post by 90GTVert on Oct 1, 2009 21:56:28 GMT -5
67MPH sounds pretty impressive to me. I was pretty sure from the get-go that the 0-50 times were off. Those numbers were too good to be true. Regardless, it's quite a scoot.
Post by 2strokd on Oct 2, 2009 7:43:01 GMT -5
Good, glad you found the history on your 9. I hadnt even thought it would be out there in another forum. Good to know, if i ever sell Skeedr (dought it) i will just tell the buyer they can check out everything i have done at 49ccScoot.com. 67mph is very impressive. Kymco,s like top end, my uncles is kinda slow up to about 37mph, then the motor finally catches up with the gears and it starts haulin. Its no 67mph hauler but it will do 60 and i think thats darn impressive for a stock motor with an upgear in the trans.
Post by 90GTVert on Oct 2, 2009 8:33:59 GMT -5
Good to know, if i ever sell Skeedr (dought it) i will just tell the buyer they can check out everything i have done at 49ccScoot.com. That's exactly why EVERY scooter owner needs to join our forum and share info on their scooters. ;D Your scooter will be worth more money because of the documentation you've done on it. ***DISCLAIMER : ACTUAL VALUE OF SCOOTERS MAY NOT INCREASE.***
