This is a pretty simple mount to make (assuming you can weld) for small gauges like a digital tach or bicycle speedometer. I'm mounting a Trail Tech TTO tachometer in this article. I use the stock mirror mounting location, because I installed bar end mirrors to replace the stockers.
I started out with an M8 x 1.25 thread pitch x 40mm bolt. You need a bolt that screws into your handlebar mount. You could also use a stud or all thread of the appropriate length. What I have is the most common, but there are variations. Bolt you may wish to use a longer bolt for larger gauges, but I wouldn't advise using anything much shorter than 40mm to give adequate clearance and room to install a locking nut.
Cut the head off of the bolt, and file away any sharp edges.
Screw the bolt into the handle bar mount as far as it will go by hand.
Decide where the bottom of the gauge should be and mark that spot on the bolt.
Now you'll need to find something to use as a back plate for mounting via double-sided tape or hardware. If you end up doing many custom projects, it pays to save brackets and bits of metal from other projects for times like this.
I found a cut up portion of an L bracket that will work for me. Of course you can also go out and buy steel sheet or find a bracket that will work for you.
Mark the metal and cut it to fit your gauge. Be sure to remove all sharp edges.
Clamp the backing plate to the bolt, using the mark you made previously to determine the correct position. Then weld the two together and clean them up.
Paint the bracket as you please.
You'll need a nut to secure the mount into position. I used the stock mirror's nut. I had to file the sleeve above the nut a little to make it work, but it makes a cleaner look.
Now you can screw the mount into place and secure it with the nut.
Here's my tach installed on the new mount. Very sturdy.
Last Edit: Nov 20, 2017 6:04:54 GMT -5 by 90GTVert
Senna1Rossi: Ah, gotcha! Thanks, Fox. Does everyone see the Shoutbox, or just the people who you choose?
Feb 16, 2016 12:39:35 GMT -5
Fox: Anyone who is logged in can see it but it's down at the bottom so most have either chosen to ignore it or haven't discovered it yet.
Feb 16, 2016 18:42:39 GMT -5
Deleted: Wow, I just found this. I feel smart now, ha ha.
Feb 27, 2016 19:24:24 GMT -5
Silar: Ahh.. New feature for a new riding season! YAY!
Mar 16, 2016 17:12:34 GMT -5
Silar: Apparently this still is not being used much. hmm..
Mar 17, 2016 13:55:04 GMT -5
180°off: Anyone want to buy a Yamaha 2t that needs a complete rebuild?
Mar 27, 2016 16:00:19 GMT -5
larryhobman: What is the leanest jet size you would try on a 47mm setup, 60cc stock head with a A9 cam
Apr 2, 2016 20:17:30 GMT -5
Senna1Rossi: Thanks renagade281!
May 23, 2016 14:59:12 GMT -5
Fox: I don't really know how to say this but straight. I am Dave's Girlfriend Kellilee and bluntly and VERY SADLY he passed away early Tuesday morning. I know he would want ya all to know this. Thank You Brent for befriending my love he was very happy on here!
Jun 18, 2016 16:26:04 GMT -5
Fox: www.gofundme.com/29mgf6b8 I hope it is ok to pass on his gofundme page link. If not you will un-post it I'm sure. Thanks again all!!
Jun 18, 2016 16:31:18 GMT -5
