Post by 2strokd on Feb 8, 2011 9:11:59 GMT -5
Yeah, heck yeah!!!! Great work on the 12HP BTW!!
Post by lshigham on Feb 8, 2011 9:22:37 GMT -5
Yeah, heck yeah!!!! Great work on the 12HP BTW!! I worked out how much that 12HP cost earlier today. About $3500
Post by lshigham on Feb 8, 2011 9:22:58 GMT -5
Oh, and that doesn't include the scoot at about $5000.
Post by shakerdriver on Feb 8, 2011 9:32:10 GMT -5
Damn it, thats about $710 per horsey.
Post by lshigham on Feb 8, 2011 9:37:18 GMT -5
Ouch, makes a 50cc china scoot look cheap at about $100 a horsey.
Post by shakerdriver on Feb 8, 2011 9:51:59 GMT -5
yeah but i'd rather spend the money and have something to ride rather than always complaining about not going anywhere.
Post by lshigham on Feb 8, 2011 16:06:59 GMT -5
Oh yes, it certainly goes.
I'm off out to clean and check the carb.
Post by lshigham on Feb 9, 2011 11:35:30 GMT -5
Well, it took me a little longer than anticipated, but I did manage to clean the carb.
I found that a few of the atomizer holes were blocked, which would certainly explain my problems. Thanks for the suggestions, and I will report back when I know if it's fixed.
Post by lshigham on Feb 10, 2011 7:49:39 GMT -5
Nope, still broked I'll get my multimeter out later and check the ignition system.
Post by 2strokd on Feb 10, 2011 12:12:37 GMT -5
Reeds??? Hows the compression?
Post by lshigham on Feb 10, 2011 12:16:46 GMT -5
Reeds??? Hows the compression? Reeds are fine, I checked them on the weekend. I tore the top end down yesterday to de-carbon it, nothing scored or seized. It's only done 400mi on the kit.
Post by lshigham on Feb 10, 2011 15:49:57 GMT -5
I may have a possible cause. If given a 7mm gap to jump (the min needed to spark in the compression of the combustion chamber) the spark will often go through the insulation of the HT lead and spark to anything nearby (water hose, frame, throttle cable etc.). In it's current position the HT lead rests on the frame, so I've shortened and moved it so there's at least a 1'' gap.
Post by 2strokd on Feb 10, 2011 15:54:28 GMT -5
Hope thats it!
Post by lshigham on Feb 10, 2011 16:04:43 GMT -5
So do I. If it is I will be annoyed with myself, as round the time it started to play up I replaced the plug cap and HT lead using a lead about twice as long. If isn't I'll be annoyed with the scoot
Post by Thebatman on Feb 10, 2011 21:13:14 GMT -5
I hope you get it to.. Man, your better than me. Electrical is very weak in my portfolio. ;D I would have done broke something... (as my threads prove :rofl: )
