Post by jimmyjam1358 on Aug 24, 2015 14:09:49 GMT -5
I have been a 49cc guy for a couple of years now, I have a T3 with a couple of upgrades, recently changed to a 23mm carb ran great, good throttle response but had some issues and replaced the fuel pump, now having issues at over 30mph of missing and no power. I did install a K&N Filter any suggestions, have installed a Trail Tech Vapor and cant seem to get over 7300 RPM as well. Thanks
Post by derbiman on Aug 24, 2015 14:33:06 GMT -5
23mm carb? Did you upjet with the open air filter?
Post by scooterpimp on Aug 24, 2015 19:47:23 GMT -5
Post by katastroff on Aug 24, 2015 20:20:49 GMT -5
Post by birdman on Aug 25, 2015 4:17:24 GMT -5
Sounds like its lean to me.
Post by aeroxbud on Aug 25, 2015 4:28:00 GMT -5
welcome to the forum Jimmy. cant you put the standard filter back on and see if it makes a difference.
jimmyjam358
Post by jimmyjam358 on Aug 25, 2015 13:52:47 GMT -5
I did, main jet is a 100 really light variators for high rpm, no air filter runs fast 44 mph, working on a better setup now, the k & n filter is just a little big for where it mounts, had to run the cable to the carb upside down if you will. Cant seem to find a hose that will work to relocate the filter. Thanks for the replies, and no stock air box has been dismantled tried to scavenge parts off to move the air filter away from motor.
jimmyjam358
Post by jimmyjam358 on Aug 25, 2015 13:53:32 GMT -5
Thinking of going with an electric fuel pump have read a couple of places that could be my issue with running at high rpm all the time?
Post by 90GTVert on Aug 25, 2015 16:05:25 GMT -5
The electric pump could be more trouble than it's worth because the electrical systems don't exactly have a lot of headroom on these things. If you want a better pump than stock, try a Mikuni. They supply bigger engines without issue.
jimmyjam358
Post by jimmyjam358 on Aug 25, 2015 16:15:33 GMT -5
Thanks will look into that this week
jimmyjam358
Post by jimmyjam358 on Aug 25, 2015 16:40:48 GMT -5
Maybe I will apply for the speed list too, hmmm
Post by scooterpimp on Aug 28, 2015 18:04:29 GMT -5
Ditto on the mikuni pump, ruck clone starts , idles etc. Like it was injected after mikuni was used.
