Post by wannagofast on Aug 30, 2015 22:02:43 GMT -5
Fundage tight so can't upgrade to a bigger carb so will be running 19mm dellorto on tpr 86cc kit My parts I am ordering are 1.tpr 86cc lc kit 2.polini hi speed vario 3.motoforce electric water pump 4.motoforce racing 105mm clutch and bell And later a large carb but cross that path when I can order one
Post by niz76 on Aug 30, 2015 23:30:58 GMT -5
Cool. Would love to see a build thread!
Post by wannagofast on Aug 30, 2015 23:44:41 GMT -5
I will update as I go and working on mounting radiator in cubby and and I am wondering with a 19 mm dellorto carb the largest jet I have is a 110 ,will this work without running lean
Post by spaz12 on Aug 31, 2015 0:18:48 GMT -5
Fundage tight so can't upgrade to a bigger carb so will be running 19mm dellorto on tpr 86cc kit My parts I am ordering are 1.tpr 86cc lc kit 2.polini hi speed vario 3.motoforce electric water pump 4.motoforce racing 105mm clutch and bell And later a large carb but cross that path when I can order one I gave you a link on ZF. I would have been more specific if I knew whether or not you were running an open filter or something different. Anyway, it should get you close. And of course you already know that that carb is probably dangerously small?
Post by birdman on Aug 31, 2015 3:47:32 GMT -5
I would think a 21mm-24mm carburetor if it was me.
Post by wannagofast on Aug 31, 2015 10:48:50 GMT -5
People go onto forums to help figure stuff out and get ideas and knowledge , I mentioned I already read up on that article and does not give me info I was looking for . I ran s6 pro rep pipe , 19mm dellorto carb and s6 sport mkII and jetted at 110 ran like a top but ceased up and by that article should of been fine so on almost a 1000.00 build I was looking for more input
Post by iwiketuddlz on Aug 31, 2015 13:15:55 GMT -5
I would run at least a 28mm keihin 24mm at the smallest with the setup you have described and it will run very good I'm sure!!!
Post by spaz12 on Aug 31, 2015 14:21:48 GMT -5
People go onto forums to help figure stuff out and get ideas and knowledge , I mentioned I already read up on that article and does not give me info I was looking for . I ran s6 pro rep pipe , 19mm dellorto carb and s6 sport mkII and jetted at 110 ran like a top but ceased up and by that article should of been fine so on almost a 1000.00 build I was looking for more input My bad, I didn't see anywhere in here that you'd already read the article. I probably should have said right off the bat that your carb is too small.
Post by wannagofast on Aug 31, 2015 17:10:13 GMT -5
Thats because I wrote that over on the ZFs
Post by wannagofast on Aug 31, 2015 17:12:22 GMT -5
What would be better a pwk with or with out power jet ?
Post by spaz12 on Aug 31, 2015 19:52:16 GMT -5
Well, where would you get the signal to energize the solenoid? And at what rpm since this is a scooter? I suppose you could figure it how somehow, but I wouldn't know how. Although I imagine you get the signal from the cdi, I really don't know Until you figure that out you have to use a standard pwk.
Post by moofus02 on Aug 31, 2015 19:59:45 GMT -5
i would go without powerjet but you can get a blockoff jet to disable the powerjet from treateland.tv i think
Post by Lucass2T on Sept 1, 2015 3:36:45 GMT -5
Powerjets have no real use on a cvt engine. They rarely go into overrevs which make the powerjet kinda useless. More useful on a bike with gears.
With that 86 TPR and the right pipe (malossi 86 big bore, 2f4r, polini big evo, yasuni c21/30, Jolly moto, Roost etc) you can easily squueze out 20 hp which makes the engine screaming for a 28mm carb.
Yeah 19 is way too small and that s6 pipe is more like a restrictor. Maybe the tailpipe is too narrow and the engine seized because of that...temps getting too high.
Post by birdman on Sept 1, 2015 3:38:58 GMT -5
I do believe only the 24 comes with a powerjet...
Post by Lucass2T on Sept 1, 2015 3:43:06 GMT -5
I do believe only the 24 comes with a powerjet... Originally every PWK 28mm has a powerjet. Keihin makes the PWK carb and those have a powerjet. But there are TONS of replica PWK's like OKO, Motoforce, stage6 and those don't always have powerjet. Lots of ppl put a 0 jet in the powerjet.
