Post by colddog on Sept 20, 2015 18:10:23 GMT -5
Uh-oh.... Found the culprit.... My carb isn't feeding me gas only when I give it throttle. I found a carb for 20 bucks should I buy it? I don't mind spending 20 bucks thank you guys for everything
Post by Fox on Sept 20, 2015 21:20:25 GMT -5
Did you take it apart and clean it? It's a must do on any scooter that has sat for more than a month or two. The idle jet is the issue. It's blocked. Use a bristle from a wire brush to clear out the clog after soaking the jet in some carb cleaner for a while. Spray 1/4 in. of carb cleaner in a small container and then drop the idle jet in there and put a cover on it to keep the carb spray from evaporating real fast. Carb cleaning guide in part two of this post: 49ccscoot.proboards.com/thread/363/carburetor-cleaning
Post by colddog on Sept 21, 2015 5:51:15 GMT -5
Did you take it apart and clean it? It's a must do on any scooter that has sat for more than a month or two. The idle jet is the issue. It's blocked. Use a bristle from a wire brush to clear out the clog after soaking the jet in some carb cleaner for a while. Spray 1/4 in. of carb cleaner in a small container and then drop the idle jet in there and put a cover on it to keep the carb spray from evaporating real fast. Carb cleaning guide in part two of this post: 49ccscoot.proboards.com/thread/363/carburetor-cleaningDid that with the pilot jet and main jet, thank you though.
Post by colddog on Sept 21, 2015 14:22:29 GMT -5
can this part make your headlights not work? They don't turn on and when I put high beams it doesn't do anything not even on the cluster
Post by luther99 on Sept 21, 2015 16:57:15 GMT -5
I got myself the same one just a few days ago for my first. But I need to get my licence first so I can fridge that's what the dmv said.
Post by colddog on Sept 21, 2015 17:51:52 GMT -5
I got myself the same one just a few days ago for my first. But I need to get my licence first so I can fridge that's what the dmv said. Congrats, hope you enjoy it
Post by walleye1963 on Sept 21, 2015 18:52:43 GMT -5
can this part make your headlights not work? They don't turn on and when I put high beams it doesn't do anything not even on the cluste . Plug it in see what happens.your lights should work then.
Post by pgs on Sept 21, 2015 18:59:39 GMT -5
can this part make your headlights not work? They don't turn on and when I put high beams it doesn't do anything not even on the cluste . Plug it in see what happens.your lights should work then. looks like the regulator lights would not work without it
Post by colddog on Sept 21, 2015 20:07:31 GMT -5
looks like the regulator lights would not work without it Thanks you so much! I'll order a new one later. Have a good one
yeska
Post by yeska on Oct 15, 2015 20:45:32 GMT -5
Vienvenido paisa jajajaja u should buy a ac cdi the blue one and kunfu or kein caburburator and a gas filter with magnet and pomp 87 gas try it work for me and my tao tao speedy 2014
Post by escootn on Oct 20, 2015 22:55:18 GMT -5
I've had my first scooter for a few months now and consistently have a problem getting it to run what is wrong? Engine turns over but doesn't run or even idle for any amount of time. It ran fine 2 days ago and now exhaust coughs.
Post by spaz12 on Oct 21, 2015 1:13:37 GMT -5
Post by aeroxbud on Oct 21, 2015 4:02:44 GMT -5
I've had my first scooter for a few months now and consistently have a problem getting it to run what is wrong? Engine turns over but doesn't run or even idle for any amount of time. It ran fine 2 days ago and now exhaust coughs. Welcome to the forum escootn
Post by escootn on Oct 21, 2015 15:15:30 GMT -5
Thank you preciate the hospitality
Post by escootn on Oct 21, 2015 23:22:44 GMT -5
Spaz12 I read the thread but I still can't find nothing that pertains to my issue being that my first scooter is used not bought any thoughts I need this fixed asap
