Post by spaz12 on Sept 24, 2015 4:55:59 GMT -5
Dude check out the bad ass cases on eBay .... Search (stage6) and you will find them ...like wow if I had the cash id get them Yes you can use it with rear facing carb. I have another CVT cover that you see on my Aerox motor but I don't know if it will fit your motor. It will fit the Zuma (sorta) with a few of the mounting holes not lining up. It does work though and the kick starter works as well.
Post by iwiketuddlz on Sept 24, 2015 5:03:51 GMT -5
Mmm that's odd I thought Zuma and aerox are the same like cvt and gear wise ??you want to sell it?? Or no
Post by spaz12 on Sept 24, 2015 5:09:25 GMT -5
Mmm that's odd I thought Zuma and aerox are the same like cvt and gear wise ?? For the most part they are. But the cvt on the Aerox is the same as the prebug cvt. They are just slightly different. On the Aerox we can also change both the primary AND secondary gears. Haha, I don't know why I was thinking that you were mounting the cover on the motor you have now.. You need one for your Aerox motor. I got ya. Anyway, I have another exactly like in my pictures or I can get you links to a few more tomorrow. I'm dead tired.
Post by spaz12 on Sept 24, 2015 13:55:27 GMT -5
Post by spaz12 on Sept 24, 2015 17:52:44 GMT -5
If you could measure and tell me the distance between the two holes that go on the crank case and the distance between the hole from the crank case to the exhaust side then I will be able to tell if it fits or not. Aerox and Zuma are big Scooters so not sure if it fits a Jog. Sorry Tsimi, I didn't see this earlier. The distance on the piece is roughly 9.5 mm between holes (center to center). You could always make a plate something similar to this so that you can put the holes wherever you need them. I believe that I will have to do the same for mine.
Post by tsimi on Sept 24, 2015 18:32:59 GMT -5
Thank you spaz12 and what about the distance between one hole crank case side to the other hole on the exhaust side? So that i know the width of that fender.
Post by spaz12 on Sept 24, 2015 22:16:52 GMT -5
Thank you spaz12 and what about the distance between one hole crank case side to the other hole on the exhaust side? So that i know the width of that fender. It's approximately 28mm from one side to the other tsimi.
Post by tsimi on Sept 25, 2015 5:58:26 GMT -5
spaz12As I thought it doesn't fit. It is way too large in width. The space of my Jog is around 20cm from exhaust bolt to the other sides crank case hole. And on the crank case side, the holes are 10.2cm apart. I might take one of these and just paint it.
Post by derbiman on Sept 26, 2015 16:54:29 GMT -5
You can make your fender look like carbon fiber by sanding and prepping it. Then apply a black base coat and let it dry. Get some fiberglass mesh tape used for drywall repair and carefully apply it to the fender making sure it is firmly attached to the fender. Then apply a coat or 2 of silver paint. Let it dry and peel off the tape. Then apply several coats of clear. Boom!!! Instant faux carbon fiber.
Post by Jwhood on Sept 26, 2015 20:45:16 GMT -5
Wonder if one of those sub frames would fit my tgb Franco morini engine,it is top mount??
Post by iwiketuddlz on Sept 27, 2015 7:14:08 GMT -5
Yes I seen that lol heck if was the whole thing cylinder and all I woulda done jumped on that.!!! But even for the current price it isn't too awful bad for ported disc brake cases ya know.?? And you say you have another fender like that one in pic?? Or am I dreaming Thanks spaz you da man!!!
Post by spaz12 on Sept 27, 2015 13:53:24 GMT -5
I don't have another fender iwiketuddlz. I have another cvt cover.
Post by iwiketuddlz on Oct 16, 2015 23:01:19 GMT -5
I don't have another fender iwiketuddlz. I have another cvt cover. Yea yea cvt cover that's what I meant .... Me want!!
Post by spaz12 on Oct 17, 2015 0:24:36 GMT -5
I don't have another fender iwiketuddlz. I have another cvt cover. Yea yea cvt cover that's what I meant .... Me want!! I have it and it's still in the box, unopened
Post by iwiketuddlz on Oct 21, 2015 13:42:35 GMT -5
Yea yea cvt cover that's what I meant .... Me want!! I have it and it's still in the box, unopened Mmm?? Will you save it?? I'm broke right now but I do certainly want it !!!!
