Post by 2001eton on Sept 28, 2015 18:37:07 GMT -5
Yea if i had a bad csi regulator or stator would i get any light on a test light and also when i get start it the light on the dash comes on thats all i know
Post by spaz12 on Sept 28, 2015 18:41:22 GMT -5
Sure, the test light will light up with not much voltage at all. Of course it will be dimmer, but you don't know the specific voltages that you need to make the system work.
Also, is there a fully charged battery in it now? I know that you said it ran before without one, but well, I don't see how. I'd suggest if you don't have one, then get one and try again.
Post by 2001eton on Sept 28, 2015 18:42:29 GMT -5
No battery no key no nothing
Post by spaz12 on Sept 28, 2015 18:44:19 GMT -5
You seem to be in quite a pickle
Post by spaz12 on Sept 28, 2015 18:47:16 GMT -5
With everything I know about the E-ton beemer (admittedly not a whole lot) it should not run without a good battery because they are DC cdi's. Even looking at the picture I can see that it has a DC cdi. You need a battery.
Post by 2001eton on Sept 28, 2015 18:49:33 GMT -5
It lost spark when running i tried to upload a video and that didnt work but heres a screen shot .. And all the info i reserched about cdis where of theres 2 in the 2 prong its ac if its 1 its dc also talked about the 4 prong but nothing i read said anything about 2 and 2
Post by spaz12 on Sept 28, 2015 18:51:49 GMT -5
Well, then I'm stumped.
Post by 2001eton on Sept 28, 2015 18:52:35 GMT -5
Me too thats why i decided to join a fourm either what i read is contradicting or just not the info i need
Post by spaz12 on Sept 28, 2015 18:58:30 GMT -5
Well, I think it's worth a try to throw a battery in it and see if it helps. It's not good to run any scoot without a battery anyway, no matter if they are AC or DC.
Post by 2001eton on Sept 28, 2015 18:59:49 GMT -5
I have one now running with out a battery.. Can i use a car charger to charge a moped bat
Post by spaz12 on Sept 28, 2015 19:03:52 GMT -5
Yes you can.
Post by 2001eton on Sept 28, 2015 19:04:02 GMT -5
Ill try it then see if i can find one
Post by 2001eton on Sept 28, 2015 19:14:55 GMT -5
I have a batt charging its reading .3 volts i should let it charge to 12 right?
Post by spaz12 on Sept 28, 2015 19:16:34 GMT -5
Point 3 volts? Hopefully it'll charge. If it'll charge, then yes, 12 volts
Post by 2001eton on Sept 28, 2015 19:17:22 GMT -5
Ok i dont need this thing exploding on me
