Post by 2001eton on Sept 28, 2015 19:18:47 GMT -5
Its charging
Post by 2001eton on Sept 28, 2015 19:48:52 GMT -5
Batt a no go too big
Post by spaz12 on Sept 28, 2015 19:54:34 GMT -5
Use some jumper wires. This is just for a test.
Post by moofus02 on Sept 28, 2015 20:05:12 GMT -5
spaz you are right that is dc cdi. they will run sometimes without a bat but it is hard on them hook the charger up to the bat terminals and then check for spark. without a battery it has to make enough juice to power the cdiwhile you kick it. sometimes it works sometimes not but the spark will be week. with a dead or junk bat the bat will suck up all the power and the cdi doesnt get any. use the charger to power the system and see if it works. you should always run a good bat in a eton
Post by 2001eton on Sept 28, 2015 20:06:53 GMT -5
I have the black grounded positive hooked up kicked it over no spark but the dash lights and everything are on
Post by katastroff on Sept 28, 2015 20:11:04 GMT -5
Have you check the ground wire from the frame to the engine?
Post by spaz12 on Sept 28, 2015 20:11:46 GMT -5
spaz you are right that is dc cdi. they will run sometimes without a bat but it is hard on them hook the charger up to the bat terminals and then check for spark. without a battery it has to make enough juice to power the cdiwhile you kick it. sometimes it works sometimes not but the spark will be week. with a dead or junk bat the bat will suck up all the power and the cdi doesnt get any. use the charger to power the system and see if it works. you should always run a good bat in a eton Thanks, I knew that I wasn't losing my mind. I didn't know that they'd run without a battery though. Thanks for that clarification.
Post by 2001eton on Sept 28, 2015 20:12:42 GMT -5
Thats where i had the negative on if ur talking about this ..
Post by derbiman on Sept 28, 2015 20:13:07 GMT -5
That is pretty much a sure sign that your cdi is dc. The headlight will come on with the key. The ac cdi operates off of the stator. Could be a bad cdi.
Post by 2001eton on Sept 28, 2015 20:14:04 GMT -5
I never got the head lights on just bthe dash
Post by 2001eton on Sept 28, 2015 20:15:35 GMT -5
The ignitin coil that was on it was sliped and bare wire if that wire hit the metel could that have shorted the cdi a bit to do this?
Post by katastroff on Sept 28, 2015 20:19:16 GMT -5
Thats where i had the negative on if ur talking about this .. The wire should run from the crankcase to the frame, you got another one from the harness to the frame.
Post by 2001eton on Sept 28, 2015 20:20:37 GMT -5
Ok let me look see if i can find anything
Post by 2001eton on Sept 28, 2015 20:24:07 GMT -5
I dont see anything
Post by katastroff on Sept 28, 2015 20:26:50 GMT -5
Could be just that. Put one up and try.
