Post by colddog on Oct 5, 2015 17:10:22 GMT -5
So I got my scooter running for a week or two and today it decides to be a snitch again and starts acting up, I put a new wire and spark plug. New carb with #75 jet and #35. New CDI new rectifier. And now it bogs out adjusted the air and fuel mixture, nothing. Idle screw nothing. Even has a new petcock/diaphragm. I have no clue what's going on a lil help would help in so many ways. Also has new fuel filter and lines.
Post by katastroff on Oct 5, 2015 17:22:37 GMT -5
Take all of those new parts off, then reinstalled them 1 at the time and see witch one will give you those symtoms.
Not all carbs of the same size will give you the same performance.
Post by colddog on Oct 5, 2015 17:29:44 GMT -5
I'll try that and I'll let you know what happens thank you
Post by colddog on Oct 5, 2015 17:38:27 GMT -5
Also the old carb had #33 and #18 jets on it, while the new has #75 #35 pretty big difference maybe I'm overlooking something? Friend gave me an air intake might try it after I reinstalled everything and if its working better to see if it works out fine. Also do you think it needs a valve adjustment I have not been able to do it cause I don't have the tool to measure it, heard it should be 00.3 and 00.4. Not sure though.
Post by katastroff on Oct 5, 2015 17:54:46 GMT -5
The redneck way to check your valves is with a cola can. Cut a piece of it and use it as a feeler gauge, the thickness is between .002 and .003 witch is a very acceptable valve lash.
P.S.: A beer can will work too.
Post by colddog on Oct 5, 2015 17:57:46 GMT -5
The redneck way to check your valves is with a cola can. Cut a piece of it and use it as a feeler gauge, the thickness is between .002 and .003 witch is a very acceptable valve lash. P.S.: A beer can will work too. You my friend are one heck of a life saver. Thank you so much I'll go get an empty bee.... Errr soda can and try it XD
Post by paulmohr on Oct 5, 2015 18:46:46 GMT -5
A 75 main jet sounds about right, but the 35 pilot jet might be a bit big. Can you turn your air fuel screw all the way in without the engine dying? If you can the pilot jet is too big.
A 33 main jet and 18 pilot jet I think would be waaaay lean. I didn't even know you could get a 33 main jet. That would be more the size of a stock pilot jet. Maybe it was a carb that uses a different numbering system, they are not all the same?
Also don't forget about the metering rod, spring and diaphragm. That could also cause it to bog down under a load.
I agree with Kat, try swapping out parts one at a time to see if you can isolate which part might be causing the problem. If your scooter truly had a 33 main jet and 18 pilot jumping to a 75 and a 35 is a HUGE step. However normally with a stock carb I think they run around 75 main and 31-33 pilot. I have only worked on a few scooters though so I could be wrong. Maybe someone with more experience can confirm or correct me.
Post by colddog on Oct 5, 2015 18:52:04 GMT -5
A 75 main jet sounds about right, but the 35 pilot jet might be a bit big. Can you turn your air fuel screw all the way in without the engine dying? If you can the pilot jet is too big. A 33 main jet and 18 pilot jet I think would be waaaay lean. I didn't even know you could get a 33 main jet. That would be more the size of a stock pilot jet. Maybe it was a carb that uses a different numbering system, they are not all the same? Also don't forget about the metering rod, spring and diaphragm. That could also cause it to bog down under a load. I agree with Kat, try swapping out parts one at a time to see if you can isolate which part might be causing the problem. If your scooter truly had a 33 main jet and 18 pilot jumping to a 75 and a 35 is a HUGE step. However normally with a stock carb I think they run around 75 main and 31-33 pilot. I have only worked on a few scooters though so I could be wrong. Maybe someone with more experience can confirm or correct me. Currently working on reinstalling parts one at a time, thanks for the help and yea I found it weird those where the numbers on the main and pilot jet.
Post by colddog on Oct 5, 2015 19:37:01 GMT -5
Okay uninstalled and reinstalled everything one by one, noticed that it turns on faster now but it still bogs out, I'll have the check the diaphragm on the carb.
Post by colddog on Oct 9, 2015 20:42:30 GMT -5
It was the valves guys took my time and fixed it now it an idle till it run out of fuel! Just gotta adjust the carburetor.
Post by colddog on Oct 10, 2015 10:58:55 GMT -5
It's working like a dream now thank you all for your help. You guys have been amazing.
