Post by hunt78 on Feb 25, 2011 15:03:22 GMT -5
i looked through the technical area under the maintainance topics and i can't seem to find the drain plug for the gear oil or for that matter where to put it lol its a 2 stroker keeway flash 50 49cc could someone please help and would anyone know where the cdi wiring no rev wire is so i can snip it please it a bitch when ur engine is cold lol thanks
Post by shakerdriver on Feb 25, 2011 15:22:32 GMT -5
well generally speaking the rev limit wire on the cdi's usually the green wire, but no gaurantee. the one on my E-ton stuff was crammed in behind the cdi, not in the harness. as for the drain plug, it should be way up under the tranny facing straight up toward the gears. usually a 10mm bolt head btw.
Post by hunt78 on Feb 25, 2011 15:24:38 GMT -5
thanks man
Post by shakerdriver on Feb 25, 2011 15:27:46 GMT -5
your welcome.
Post by 90GTVert on Feb 25, 2011 22:54:49 GMT -5
