Post by 90GTVert on Nov 11, 2015 11:55:20 GMT -5
This thread is full of all sorts of specifications for Chinese 139QMB / 1P39QMB engines. There are some strange variations in Chinese scooters, so it's always best to check your scooter before working on it or ordering parts for it and consult a service manual. Use the info here at your own risk. BearingsCrankshaft, CVT Side Number | I.D. | O.D.
| Thickness
| 6204 C3
| 20mm
| 47mm
| 14mm
Crankshaft, Stator Side Number | I.D. | O.D.
| Thickness
| See Below.
| 17mm
| 42mm
| 13mm
These bearings are not a common size. They may be marked in different ways, including 6302-SP, CS-SC03A39, or other designations. A typical 6302 bearings does NOT work because it has a smaller inside diameter. Honda part # 91002-HP1-671 should work or you can search for 17x42x13 bearings and find them from other manufactures or find the special bearings for this engine. Gearbox  Seals Crankshaft, CVT Side I.D.
| O.D.
| Thickness
| 19.8mm
| 30mm
| 5mm
Crankshaft, Stator Side I.D.
| O.D.
| Thickness
| 16.4mm
| 30mm
| 5mm
Primary Drive Shaft I.D. | O.D.
| Thickness
| 17mm
| 30mm
| 6mm
Rear Axle I.D. | O.D.
| Thickness
| 27mm
| 42mm
| 7mm
BushingsEngine Mount (x2) I.D. | O.D.
| Thickness
| 10mm
| 28mm
| 22mm
Rear Shock Mount I.D. | O.D.
| Thickness
| 8mm
| 20mm
| 19mm
Other InfoNGK Spark Plug Numbers : CR7HS, CR7HIX (iridium) Spark Plug Gap : 0.024"-0.028" / 0.6mm-0.7mm Valve Clearance/Lash : 0.002"-0.005" (Commonly Used : 0.002" Intake / 0.003" Exhaust) Engine Oil Drain Bolt : M12x1.50 Gear Oil Drain Bolt : M8x1.25 Magnetic Drain Plug Kit At AmazonFlywheel Puller : M24x1.0 RH Flywheel Puller On Amazon Torque SpecsDescription
| Torque | Axle Nut (Rear Wheel)
| 70-80ft-lb
| Clutch Bell Nut
| 35-40ft-lb
| Clutch/Torque Driver Nut
| 35-40ft-lb
| Cylinder Head Nut (x4)
| 10-15ft-lb
| Side Cylinder Bolts (x2)
| 6-8ft-lb
| Flywheel Nut
| 30-35ft-lb
| Variator Nut
| 28-35ft-lb
| Thread Size
| Torque
| M6
| 6-9ft-lb
| M8
| 10-20ft-lb
