Post by anemsguy on Nov 14, 2015 23:26:44 GMT -5
Just upgraded my scoot from a 50cc-150cc Scoot. What a difference. Was a fun project. My question is, how can I install a center stand? It's a handsome boy style sunny scooter. Old engine had mounts for the stand at bottom of engine. There's no mounts on this engine for a center stand. Anyone have any clue how a 150 mounts its stand and where I can find a universal stand? Been searching for 2 days online
Post by 90GTVert on Nov 15, 2015 7:51:54 GMT -5
It mounts to the frame for the 150s. You can see an example in this vid :
Post by anemsguy on Nov 16, 2015 8:53:52 GMT -5
Just what I was looking for. Thanks so much
Post by sjfishon on Nov 16, 2015 15:38:47 GMT -5
90, promise you will never leave;;
Post by stancejontland on May 13, 2017 22:01:41 GMT -5
how can i fix and or get a new center stand for my scoot. i think mine is bent or something it does t take the rear wheel off the ground.
Post by 90GTVert on May 14, 2017 6:45:29 GMT -5
how can i fix and or get a new center stand for my scoot. i think mine is bent or something it does t take the rear wheel off the ground. Some things that may seem unrelated, but can cause that issue : -Using a larger rear tire -Longer rear shock -Adding weight to the rear -Removing weight from the front Prob easiest to replace the stand if it's bent, unless you enjoy metal fabrication and welding work. I've bought them used on eBay, because new prices are often higher than seems fair. Could check in the for sale section of the classifieds or post a wanted ad.
Post by stancejontland on May 14, 2017 21:30:54 GMT -5
I'll take pics to show u if it's in good shape or bent
Post by lostforawhile on Jun 16, 2017 22:04:47 GMT -5
wierd mine has the stand welded to the frame, but it's a 50, I need to check for a second set of mounts for a 150, as the book says it came with that size as an option, I know mine has the start solenoid like a 150, not wires out of the harness other then the wire for the coil on the solonoid
