2006 Roketa Cayman 150 (MC-27-150)
Dec 29, 2015 18:43:33 GMT -5
190mech, moofus02, and 1 more like this
Post by 90GTVert on Dec 29, 2015 18:43:33 GMT -5
I replaced the modified muffler with the stocker. I also took the screws out and put rivets in the modded muffler. Looks better and whenever I swap it back on I won't have to totally remove the clamps (didn't fit over the screws). I didn't think I modded this muffler that much, but I can see the opposite end when looking through it.
As I mentioned earlier, the front brake lever seemed to do nothing. I got the master cylinder cap off with an impact screwdriver, otherwise it wanted to strip, and found jelly in the reservoir.
I cleaned it out, then opened the bleeder screw and let it drain and pumped whatever fluid out that I could. Then I filled the master cylinder and began trying to bleed the system. It took a lot of working the lever before it finally started to get fluid going and build up pressure. Once it did, the brake felt good, but I kept bleeding and filling until the fluid that came out of the bleeder looked like what I was putting into the reservoir.
I checked the thickness of the front brake disc at 4mm, with 3mm minimum stamped into it. The pads look pretty much new. I adjusted the rear brake because it was tight in one spot.
Then I wanted to get the front fender on, but I needed to borrow the reflectors from the Venus first. I moved T1 to reach the Venus, and then moved the Venus over where I could work on it. I looked at the garage bay and thought, "I think I have a problem". Na, you can't really have too many scooters, can you?
The Roketa with front fender after drilling and mounted reflectors. Uglier than it even was stock.
Next, I wanted to work on the rear mudguard, but I thought I should at least make sure the lights work before I do anything. I hooked a charger up to the scoot to supply power and all signals and the brake light worked. It's not running ATM, so I couldn't test all lights. The starter tried to click over (the charger on 10A doesn't supply enough juice) so it should be alright once I get a good battery. The only issues I found were the horn and the turn signal flasher. The horn beeped once somewhat normal. Then it fizzled out on the next beep. Then it never worked again. The flasher clicked constantly. I have a spare, but it's the same as what's in there now. I think it will quit if the scoot ever dries out from it's bath the other day.
I cleaned the mudguard and installed it.
I didn't install the turn signals because I'd like to replace them. Both are a bit wobbly at the ends, but one is worse than the other. I'm not really sure if that's an issue or not for inspection.
I looked at stock replacements from Parts For Scooters, but they were about $30/pair shipped. I thought I could get something better for less money. I would like LEDs, but I remembered when my friend bought his CBR600RR used, they had to swap stock signals on to pass MD inspection. I tried to look up more info, after thinking about how bikes in recent years have LEDs stock, so maybe I could get them. I did find more inspection and legal info, and nothing mentioned LEDs being an issue. Still, my friend's bike did have to have the LEDs replaced to pass. I thought I better get something that's not LED, and THESE were cheap enough.
Here are links to some info I dug up if anyone in MD happens to be looking for such a thing :
This one has some MD inspection guidelines for lighting. Also, if you change the "08" to different numbers, you can access other sections about MD motorcycle inspection.
www.dsd.state.md.us/comar/comarhtml/11/11.14.03.08.htm
MD Transportation Lighting Info
After ordering the lights, I started second guessing my decision. Maybe it had nothing to do with LEDs and was about DOT approval. I did some googling and found a many complaints on motorcycle forums of being failed for signals that are not DOT approved. It seems that if you don't have lights that are marked in raised letters that they're DOT approved, you may fail. Some people said their shop didn't care, but lots failed because of it.
I looked up the stock replacements again, and they have no DOT markings. If the lenses are interchangeable, they should work with my old lenses swapped on. I haven't ordered yet. My other option would be to find signals off of a big brand bike or scoot that would mount easily, since they should be DOT marked.
Since the horn didn't work, I pulled the front fairing off to check it out. I tried adjusting the screws, but it wouldn't make a sound. It had power getting to it. I tried hooking it directly to a battery to be certain and still nothing. I could have taken the horn off of the Venus, but since the horn is something I plan to keep, I ordered a beefier one. Didn't wanna go with the WOLO air horn style, even though I like the one I have. It needs a relay and it's pretty large. I ordered a Freeway Blaster instead that claims 130dB @ 3A (stock is 105dB @ 1.5A).
While I had the front off, I made sure the steering was tight. The wiring looked alright, but I do have a 9 pin connecter (with 8 wires) and a single wire that have nowhere to go. Looks like provisions for an alarm. I taped them off.
I finished swapping out hoses for the most part. I used Tygon for the fuel and mostly silicone for vacuum. I made sure everything had a clamp. When I ran out of stock clamps, I used worm gear hose clamps. I cut off most excess and ground and filed the ends so they weren't sharp. I also installed a larger piece of silicone hose over the fuel hose where it curves around the seat latch mount. I don't think it would be an issue, just making an effort to make it look extra safe. I'll still need to replace the hose from the valve cover to the airbox later.
I changed the oil. The gear oil was done recently when I made magnetic drain plugs for every scoot. I was going to swap the spark plug boot for an NGK, but I didn't have the right one.
EDIT : Just for more fun, I read that reflectors may also need to be DOT marked.
49ccs that need no inspection are so much easier to deal with.
