Post by drandon on Dec 28, 2015 14:31:56 GMT -5
Recently I purchased a Brisk Racing 360 Spark Plug for my 2013 Genuine ss220i Blur. Upon installation I immediately noticed a very steady idle. Much smoother than before. I think I detect a slight noticeable performance increase. The scooter throttle does indeed respond quite well. Since the Plug is without any discernible electrode (hence, 360) i believe it shall last a long while. I am happy with my purchase.
Post by Clank on Jan 15, 2016 22:30:43 GMT -5
Where did you acquire this?
larryhobman
Post by larryhobman on Feb 10, 2016 10:29:16 GMT -5
Post by Corrosion on Feb 10, 2016 11:37:40 GMT -5
Another Spark-plug that defies electrical theory: "3 SPARKS PER IGNITION DISCHARGE!" " BRISK PREMIUM MULTI-SPARK PLUG " "THE ONLY SPARK PLUG IN THE WORLD THAT PRODUCE THREE SPARK PER IGNITION IMPULSE !" electricity follows the path of least resistance. So It will only ever jump the smallest of the spark-plugs gap's. also, there is only one firing event per charge. With a CDI ignition, so it can only fire the plug once in the power stroke... It very well could have a smother idle, I noticed quicker starts and better idle with the iridium plug's. but the same could be said of a new standard plug, if the old one was worn. Not to condemn or deny its ability's. Just saying they would need to prove the multiple spark event, for me to swallow it. www.youtube.com/watch?v=9PJweiCRFoUI just watched the U-Tube. it is one spark event traveling across 2 conducting bands to the plug body. so in essence it has to travel an extended distance to accomplish the 3 sparks. Better have Good KV available. so in essence, it is one spark event at 3 separate location's happening at the set spark timing. I wonder what the actual spark-gap is. being as it is not adjustable in any way.
Post by Lucass2T on Feb 26, 2016 6:10:51 GMT -5
I think the coil will get quite a beating with this plug. You'll prob need a very high output coil otherwise it might wear out pretty quick...
