Post by nevada1 on Mar 12, 2011 9:03:59 GMT -5
just purchased a 2007 2 stroke vento,and I would like to get it running if possible. the wires that goto the switch are not connected,there are three terminals on the back of switch one terminal reads batt the other reads ign ? and the third is blank? I am new to scooters and I would hate to burn up any wiring,and I looked everywhere for a 2007 vento owners manual / tech specs w/o any luck . the best info I have found has been here about mods and maintenance which has been great.would send a pic but I am not that savy about posting pics here. thanks in advance for any and all help....
Post by billw129 on Mar 12, 2011 9:24:13 GMT -5
I think that if you hook the battery and ing wire together that should be like turning it on and the one not labeled is a ground that when the switch is hooked up and in the off position it connects the ing wire to the ground to keep the scooter from starting.
Post by billw129 on Mar 12, 2011 9:25:36 GMT -5
by the way the scooter should kick start with out the ing switch hooked up but you will not have turn signals or electric start. that is how mine is anyway.
