Post by drc174 on Feb 16, 2016 23:24:11 GMT -5
CT. I'd pay maybe $15 including shipping, assuming you're in the US. (Unless that isn't a fair price.) Oh, need more exact info so I can find out who is the closes that can print one for you If you want to spend money, donate 5$ to Look Twice Ciny looktwicecincy.com/donate/
Post by cwazywazy on Feb 16, 2016 23:30:31 GMT -5
CT. I'd pay maybe $15 including shipping, assuming you're in the US. (Unless that isn't a fair price.) Oh, need more exact info so I can find out who is the closes that can print one for you If you want to spend money, donate 5$ to Look Twice Ciny looktwicecincy.com/donate/Oh, I see. In that case I'll PM you.
Post by paceneedsstides on Feb 17, 2016 22:21:38 GMT -5
has anyone had to extend they tach wire??
Post by gsx600racer on Feb 18, 2016 2:25:48 GMT -5
On the ones shown here, no. On the Trail Tech, yes. 16-20" and it works fine. I would just make sure the wire used to extend is the same gauge or close to it.
Post by gsx600racer on Mar 4, 2016 1:05:50 GMT -5
Bump, updated again with new sensor
Post by gsx600racer on Apr 5, 2016 2:57:31 GMT -5
Here is the temp/rpm gauge installed on the wife's 2001 Elite. I think it looks a little bulky on it, but it better than sitting in a box not being used.
Post by funkeymonkey on Jul 2, 2016 0:16:13 GMT -5
Here is the temp/rpm gauge installed on the wife's 2001 Elite. I think it looks a little bulky on it, but it better than sitting in a box not being used. Are you using the sensor it came with? one that attaches to the spark plug and whats the max temp that it has shown? Thanks
Post by gsx600racer on Jul 2, 2016 9:13:12 GMT -5
Here is the temp/rpm gauge installed on the wife's 2001 Elite. I think it looks a little bulky on it, but it better than sitting in a box not being used. Are you using the sensor it came with? one that attaches to the spark plug and whats the max temp that it has shown? Thanks No, The sensor(NTC) supplied with the gauge only goes to 302 deg. F. I had to purchase the raw(PT100) sensor which goes to 572 degrees and build my own spark plug adapter using 1/2 ring terminals that can be purchased just about anywhere. I had to drill it a tad larger to accept the 14mm plug. If you attempt, make sure you find sensors that has the insulation on the wires(mine didn't and had to solder better leads on)and I used JB weld to adhere the sensor to the to the ring terminal.(with a little crimping too) As for max temps, I don't ride her scooter much so not sure what the max temp were. The one time I did check on a ride I think they were around 250-275 range. The again her scoot engine is all stock and not ridden aggressively.
Post by funkeymonkey on Jul 2, 2016 9:38:53 GMT -5
Did you ever get your trail tech spark plug adapter and try it with the gauge? I have a different multi gauge pretty close to what that is but this one has longer cables and the light stays on, mine though i can switch it to pt100 setting and it stays on that with the standard spark plug cable plugged in.
Post by Deleted on Jul 2, 2016 13:03:44 GMT -5
This is really helpful info. I thank all of you for testing this stuff.
Bill
Post by gsx600racer on Jul 2, 2016 15:31:06 GMT -5
Did you ever get your trail tech spark plug adapter and try it with the gauge? I have a different multi gauge pretty close to what that is but this one has longer cables and the light stays on, mine though i can switch it to pt100 setting and it stays on that with the standard spark plug cable plugged in. Yup, I did not work. Now I have a spare. LOL
Post by gsx600racer on Jul 2, 2016 15:33:41 GMT -5
This is really helpful info. I thank all of you for testing this stuff. Bill No problem, was a fun science project. 90GTVert has me beat with it comes to testing. Guess you could say I was inspired by others.
