Post by ryan_ott on Mar 2, 2016 21:51:43 GMT -5
 For a rainy day Turns out to be MHR alumnium, malossi MHR crank and piston with a new spare piston. $50
Post by spaz12 on Mar 2, 2016 22:11:26 GMT -5
12 mm?
Post by ryan_ott on Mar 2, 2016 22:23:15 GMT -5
Yes sir, small spline and taper. I'm going to build up a nice lil "spare" motor.
Post by spaz12 on Mar 2, 2016 23:15:20 GMT -5
If that's an mhr and not an rhq, that puppy is pricey!
Post by nelson on Mar 2, 2016 23:53:00 GMT -5
Someone HELP ME.... Will do webcam stuff for you if you buy me:  Whoever takes up that offer, I'll double it, you can do a dual window show I have the mhr cvt set up on my jog. Tbh the hoca cvt had a higher top speed. There are advantages for the mhr though are nice also.I just think it's for higher rpm as I was told when I bought it.
Post by Clank on Mar 3, 2016 0:45:25 GMT -5
Ruck guys use mtn bike stems I think and if I knew of one that for sure fit than I might go that way. Just make sure where the stem holds the bars is the same size diameter and you should be golden.  I have a oversized 1-1/8" downhill mtb stem and bars on my ride.
Post by spaz12 on Mar 3, 2016 0:55:07 GMT -5
The Zuma's are 22mm. Whatever that works out to be? Anyway, I got one coming now.
Oh, another reason I hadn't gone with a mtn bike stem is because I couldn't picture in my head how it mounted to the steer tube and not look ugly?
Post by Raizer on Mar 3, 2016 1:28:38 GMT -5
The Zuma's are 22mm. Whatever that works out to be? Anyway, I got one coming now. 7/8" Suzuki uses smaller bars which makes it even more of a pain to convert to MTB/BMX style bars! Today I ordered a couple cheap volt meters, should match my CHT display exactly and at $1.15 why wouldn't I buy multiples haha
Post by ryan_ott on Mar 3, 2016 10:51:33 GMT -5
If that's an mhr and not an rhq, that puppy is pricey! It says MHR on the rod, I'm pretty sure my rhq has rhq on the rod.
Post by moofus02 on Mar 3, 2016 12:21:38 GMT -5
 For a rainy day Turns out to be MHR alumnium, malossi MHR crank and piston with a new spare piston. $50   Where did you pick that up? I must have missed a post. Pesky thing they call work eats into my forum time lol
Post by ryan_ott on Mar 3, 2016 12:31:58 GMT -5
It was on eBay and a good price so I couldn't pass it up. I have no immediate need for it but I have a set of cases laying around...
Post by moofus02 on Mar 3, 2016 13:18:05 GMT -5
It was on eBay and a good price so I couldn't pass it up. I have no immediate need for it but I have a set of cases laying around... You need gears for that set?
Post by ryan_ott on Mar 3, 2016 14:21:25 GMT -5
I do. I only have the shaft the clutch spins on and one othe the other loose ones. I think its 13t. I have to check
Post by moofus02 on Mar 3, 2016 16:21:00 GMT -5
I'll look and see what I got out
Post by Raizer on Mar 7, 2016 16:45:10 GMT -5
Just ordered a range of 15 main jets, 2 more spark plugs and trying to decide on a phone holder.
