Post by 90GTVert on Mar 14, 2016 9:54:35 GMT -5
I don't know specifics about each Beamer, but I think this will likely apply :
Hoirzontal AC Minarelli 2T Long case, most I've seen have 10" wheels 13.52:1 gears, Etons use or may use 3rd bearing to support the primary driveshaft Some have a manual enrichment (choke) with lever on handlebars 10mm wrist pin, small shaft/17 spline vari
Post by mistervon on Mar 14, 2016 10:03:42 GMT -5
Thanks much appreciated
Post by TheAmishSasquatch on Mar 14, 2016 17:21:25 GMT -5
I don't know much about them other then the first gen Beemer had an actual Mikuni carb, that was a direct swap to the carb on my '04 vino. It felt nicer than the stock Yamaha carb and it's super easy to tune; only 1 adjustment IIRCC.
Post by moofus02 on Mar 14, 2016 19:27:58 GMT -5
I like the Eton. My 02 is a good bike. Dc stator and cdi with a green wire loop on the back of it to cut to defeat the rev limiter. Some of the newer ones didn't have that wire and you need to replace the cdi to remove limiter. Niz76 did a cdi swap on an Eton. They use a 26 or 27mm fork tubes with a 150mm front disc.
Post by niz76 on Mar 14, 2016 20:11:50 GMT -5
Post by 2stroked on Mar 15, 2016 17:18:54 GMT -5
I have an 02 Beamer pn2 and I LOVE the thing. IMHO its as much, sometimes more, fun than my two 250s. As moofus and Niz said, simple DC system, the cdi can be swapped for a dio unit and everything will be fine. I mention the simple swap, cuz a stock E Ton cdi is damn close to 100$. the dio u it is usually less than 30.
Anyway, I digress, it's a light fun ass little bike that will flat scream with a bbk and cheap pipe.
Post by mistervon on Mar 15, 2016 19:44:30 GMT -5
UPDATE: Just bought a 2002 Alpha Sports Kaliber Ls. Doesn't run, has compression but I want to post a few pics for you guys help.
Post by etonbeamerinfoplease on Oct 31, 2023 7:44:21 GMT -5
Post by etonbeamerinfoplease on Oct 31, 2023 19:15:13 GMT -5
