zoomzoom
Post by zoomzoom on Mar 30, 2016 13:09:44 GMT -5
I've already had this built for about a month or so. It started off as me having a stock Zuma motor laying around and a bunch of brand new unused bore kits for it. My first engine combination was a 47mm bore kit with a 47.6mm high compression head, koso 1500rpm contra Spring,koso 99mm varitor, a malossi Delta clutch with white springs, stock 14.6 gears and a big 130/90/10 tire, a Leo vince zx hand made 70cc pipe, hoca intake manifold with carbon fiber reeds, with a 120 main 48 pilot inside a 24mm oko power jet carb. Stock gears were pretty limited to about 48-51mph screaming at those speeds I have no tach so I don't know how high into the rpms I was. That setup was pretty good but I got my hands on a charmo 47.6mm auxiliary ported cermic coated aluminum kit that I didn't hesitate to install, with everything else I had it was running really good I was able to push the gears to the point the were whining really bad, I hit about 56mph. It was running great but it was to good to be true the wrist pin clip broke on me on the way back from a ride through red canyon that engine setup ran great made me pretty upset so about a week ago I bought a jog90 longcase from scrappydog and pulled out my old Yamaha engine put in my new 90 with its 54mm bore kit making it a 96cc engine it's pretty quick I'm going to put some pictures up in a bit so everyone can see it.
Post by sumo210 on Mar 30, 2016 13:17:05 GMT -5
Wow i was thinkning of doing the same thing
zoomzoom
Post by zoomzoom on Mar 30, 2016 13:20:47 GMT -5
This is it in its current stage of life right now.
zoomzoom
Post by zoomzoom on Mar 30, 2016 13:22:48 GMT -5
zoomzoom
Post by zoomzoom on Mar 30, 2016 13:26:38 GMT -5
I'll make a post on how me and my friend made all the wiring jumpers and engine mounts later
Post by sumo210 on Mar 30, 2016 13:28:23 GMT -5
that really nice i have a taotao too and i was thinking of doing the same exact thing but not sure on the 2t yet
Post by nelson on Mar 30, 2016 20:24:54 GMT -5
Looks like a good swap! I had a taotao and considered doing this but I went another route. Looks good, would like to see more pics when you get time.
Post by niz76 on Mar 30, 2016 20:41:10 GMT -5
Sounds like a nice setup! If you ever decide to sell that LVHM70 pipe let me know. I've been wanting one
Post by 'O'Verse on Mar 30, 2016 23:13:31 GMT -5
What pipe are you running on the 90? Have you installed the hoca 90 variator yet? The engine rocks...doesn't it?
zoomzoom
Post by zoomzoom on Mar 31, 2016 2:02:23 GMT -5
I'm running the Leo Vince hand made zx 70 pipe. I really like the pull this engine setup has but I need just a hair bit more throttle response I can't find my intake spacer so I have to make a new one. I haven't purchased a the hoca variator yet but I think I'll just grab the koso I was running before. I've got six gram rollers in the bike now and they feel only slightly heavy but it pulls hard my buddies ministroker polini dio pulls on me after we start getting into the upper 50s I haven't had my GPS on yet but I'm doing those speed runs this weekend after I get my new front tire and front brake pads.
zoomzoom
Post by zoomzoom on Mar 31, 2016 2:03:42 GMT -5
zoomzoom
Post by zoomzoom on Mar 31, 2016 2:08:08 GMT -5
The engine is a 1e50qmf longcase jog90 from scrappydog I've been playing with there parts for a while. Most of my setups I ran were mismatched I just made sure everything was properly time and tuned and it's worked out. I didn't get to fully test out my 47.6mm Frankenstein build because of a broken wrist pin clip sucks because that was a fun build.
Post by thatcrazyguy on Mar 31, 2016 2:09:45 GMT -5
Your scooter actually looks great with the 2t in there!!
zoomzoom
Post by zoomzoom on Apr 1, 2016 10:17:22 GMT -5
I bought some 5.5 gram sliders yesterday new front brakes, shinko front tire and petcock. Im picking up a few jets today to do some rejetting and get some better top speed runs so far yesterday i got my speedo burried past the 65 mark i just got my gps dialed in yesterday. More pictures and tunning today
zoomzoom
Post by zoomzoom on Apr 1, 2016 10:19:48 GMT -5
The day it blew coming back from red rock
