Post by Reign on Mar 30, 2011 9:09:06 GMT -5
Any idea where I can find a selection of springs, or can I just cut the one that I have down to size a little at a time?
Post by 90GTVert on Mar 30, 2011 9:46:58 GMT -5
You could just cut the existing one down a bit at a time. Hardware stores often carry selections of springs. A motorcycle shop may be able to help as well.
Post by Reign on Mar 30, 2011 10:17:09 GMT -5
After taking a look at the spring from the stock carb, compared to the larger diameter spring of the PHVB carb, I'm wondering if I can make this work: PHVB spring, carb top, resting on the outside of the area, with clearance for the cable hole: Mikuni spring, carb top, resting on the INSIDE of the area, with clearance for the cable hole: PHVB spring, slide top, resting on the outside of the area with clearance for the cable hole: Mikuni spring, slide top, resting on the INSIDE of the area with clearance for the cable hole: With the Mikuni spring in place, the slide goes up the chute about 95% compared to the PHVB spring, it only goes up about 80%
