loosegrit
Too much work. Hope for another scooter run Oct 2015.
Post by loosegrit on Mar 27, 2011 17:50:35 GMT -5
I wanted 4 way flashers on my 49cc VIP for open highway travel. All I did was to run a single wire from right & left front blinker to an on & off toggle switch to my front dash. When the switch is on with either blinker on, I have 4 way lights. When switch off blinker work normal.
Post by 90GTVert on Mar 30, 2011 9:43:52 GMT -5
Great idea! I made up a simple image to illustrate it. I indicated the turn signal wires in the diagram as green with a black stripe (left) and green with a white stripe (right). Those are common colors for the turn signal wiring, but not all scooters will have the same colored wiring. Please refer to a wiring diagram or trace the wires to determine which you need to use on your scooter.
