Post by SandStorm on May 28, 2016 3:06:34 GMT -5
I'm with ideas to get rid of the old faded "stalker" sticker, and place some Ferrari logos in it (the scuderia prancing horse scudetto) and my racing number (05) in the style used for American Football. Yay or Nay?
Post by SandStorm on Jun 5, 2016 11:33:53 GMT -5
Smoked the handlebar light and sealed it. I think I smoked too much...
Post by SandStorm on Jun 7, 2016 12:54:57 GMT -5
Took out the front panel and painted it Badly painted, but whatever xD
Post by SandStorm on Jun 7, 2016 14:01:18 GMT -5
Also painted struts mud guards same color And all fitted. Had to zip tie fix one indicator because the screw hole broke and I lost the screw. Terrible job, loads of imperfections, but at least better than before
Post by spaz12 on Jun 7, 2016 14:38:56 GMT -5
Post by SandStorm on Jun 7, 2016 15:35:47 GMT -5
I'm used to spray paint, m8. Fir example, I spray painted my ford valve rocker cover with professional high temp spray paint and came perfect. The problem is that on Gillian I used the cheap made in China spray, instead of quality stuff. XD But since I wanna plastidip her... (the rubber touch paint)
Post by aeroxbud on Jun 7, 2016 19:34:33 GMT -5
Sometimes those cheap paints have really bad nozzle's fitted, which make it impossible to get a good finish. Does not look too bad in the picture's
Post by SandStorm on Jun 7, 2016 20:28:11 GMT -5
Indeed, my friend. I'll just order some candy red plastidip and spray all of her instead. Or maybe neon red plastidip
Post by SandStorm on Jun 23, 2016 16:10:22 GMT -5
Not much to say, replaced the front master cylinder, got rid of air bubbles... this until I do a better system flush. Old MC had lots of leaks and was all rusty inside. after draining (was almost empty bcs of leaks) it stopped being stuck. lol. Anyway, I'll need to sand and respray again my front fairing, and fix a crack below the front handlebar fairing, which I suppose I got it after doing some offroad. Ordered a new brake light switch, and when I have time, i'll check up my dashboard bulbs. I suppose my problem may be the circuit foil, it is too fragile and seems corroded. Thinking to order a spare one, just to replace the circuit board. unless I place in a new one instead of just swapping the circuit board, but then my traveled kilometers won't match with the reality...
Post by SandStorm on Jun 25, 2016 10:44:57 GMT -5
This was all the old oil i finished to bleed. :V
Post by SandStorm on Jul 21, 2016 12:56:27 GMT -5
Fitted these with new callipers, new hose, total disassembly and cleaning of master cylinder (had debris from the old rotten hose). Also, this time used ferodo dot4 brake fluid, instead of cheap ones. Also adjusted the brake sensor.
Post by SandStorm on Nov 1, 2016 7:38:24 GMT -5
How come I didn't shared this pic. Been a month and half without riding. Yesterday rode it, finally. Still need my plastidip and some visual care. Before yesterday did some TLC replacing some parts. The start was hard bcs was sit without being used for long. But runs flawlessly. My time has been spent on my sportscar project, a Ford puma xD
Post by SandStorm on Nov 2, 2016 13:44:45 GMT -5
Some of you may know I had some bulbs not working. Like the low fuel and low oil warning. Today I disassembled the dash and cleaned all contacts I could. Put a clock battery for the hours too. Also my speed light wasn't showing up, but fuel gauge night light was working. The speed light was burnt. So I swapped it with the clock one. The essential now works! Even the oil warning light I'll see when I'm low on fuel if that works too. Now... My high beam mid_Street testing stopped working. Heh I'll clean that one out tomorrow. Damn Italian electronics, pure junk But I love this motor
Post by SandStorm on Nov 3, 2016 8:50:33 GMT -5
Today I did some paint job. Also did it to half center stand until the can nozzle stopped spraying... (it does have paint inside, just a defective can) How it was and how my exhaust is. That grey thing is cold solder kind paste I used to cover the hole it had After it fries, I'll wash her
Post by SandStorm on Nov 3, 2016 9:27:43 GMT -5
Ready for my day-off ride, sparkling clean Looks much better with the exhaust painted
