Post by 2strokd on Oct 28, 2009 13:26:18 GMT -5
My mistake, i thought these were 6mm but they are standard 4.5mm bb,s for the gun lol. They were in a 6mm airsoft pellet container that threw me off. NO GREASE! You know better than that reign lol... yea I know, I figured I'd ask though You can never tell with as crazy as you guys are with your mods. I'll go find some 4mm bb's and throw them in tomorrow or something. Just need to upjet to 87.5 to get rid of the bog, and do this and my Triton should be set for spring. yea right, lol if your like me you will find something else to do to it before spring . What kinda bog?
Post by Reign on Oct 29, 2009 9:05:09 GMT -5
I'm sure I will find something else to do to it. I'm just going to have to keep myself from doing TOO much. Otherwise I bring it out in spring and go "oh crap, which one of the 20 things I did screwed it up" As for the bog, its bogging just a little bit from a dead stop. If I roll through a stop sign, it's fine. But if I come to a complete stop and then take off again, I get some bog. It's most likely because I still have the snorkel off the airbox. The manual for the kit recommends a 88 main jet anyways. I just wish I could've still used my iridium plug with the bb kit
Post by Reign on Nov 25, 2009 12:46:22 GMT -5
So I just went to the local gun store and grabbed some steel BB's. The only thing they had was 3000 rounds, so now I have enough for anything I figure I should only need about 35 of them, maybe 34 or 33. I'll probably put them in sometime this weekend.
Post by 2strokd on Nov 25, 2009 14:58:31 GMT -5
Cool! What T spring you running now? The bb,s will stiffen it a little....
Post by Reign on Nov 25, 2009 15:05:58 GMT -5
Cool! What T spring you running now? The bb,s will stiffen it a little.... I'm running a yellow 1500 RPM torque spring right now.
Post by Thebatman on Sept 29, 2010 10:56:27 GMT -5
what ever happened with this trick? still good? ?
Post by 2strokd on Sept 29, 2010 11:20:39 GMT -5
I took mine out long ago for a new spring, but the trick works if your torque spring is weak. Lighter weights help comp for a weak t.spring too.
