Post by chehystpewpur on Jun 16, 2016 20:21:43 GMT -5
well as the title says here in the next few months i should be running around on a turbocharged 2t for shits and giggles. ive always wanted to attempt it and now that my scooter isnt getting any love due to me having a real car with 4 wheels so i need a reason to drive ole betsy. in the last few months ive been doing tons of research on the old and new 2t sleds and banshees that got turboed and from the sounds of it most of them remained fairly untouched to accept boost. ive been playing with some ideas in my head to aid with the problems if the boost charge blowing straight past the combustion chamber and i think i may have found a winning combo to help fight that though from a physics standpoint the minarellis's we all love have a big helping hand with the air and fuel going into the crank case before the cylinder. some old 2t engines ive played with the intake was on the cylinder those would be impossible.
supposedly boost busters over on youtube managed to place their am6 shifter engine in a crotch rocket frame and get some pretty interesting results from it but alas mine only have a cvt and trans designed to stay in whatever powerband i choose until around 70-90 mph. www.youtube.com/watch?v=zybsu4Mwato its worth a watch please enjoy.
ive acquired 2 tiny turbos in the last year to try and get a good idea of if im going to be able to even spool the thing. one of the ones i got is a turbo from an srt4 neon. yeah it comes from a 2 liter engine but its absolutely tiny and is famed for its ability to spool if you sneeze too hard and another is a slightly larger turbo but it has variable vanes. the variable vanes are a grace from a higher power in the turbo world for those that dont know about them because they effectively let you change your exhaust housing and turbine on the fly. more or less no lag from idle then when rpms climb it readjusts to stay making constant boost without ever missing a beat. both are almost brand new and have coolant passages and oil passages. i plan on switching to liquid cooled anyways due to it getting up to 105 degrees in the summer where i live and my air cooled builds hated cruising at 55-65 mph in that heat. im going to use a crank driven water pump to get my coolant moving and i found some low wattage oil pumps for cheap that i can put a secondary oil system in for the turbo. my charging system barely even gets used anyways due to switching all of my bulbs to leds because they are brighter and use less power and carry light intensity farther. plus projectors with halos look sweet on my bike lol.
ill still be using a carb for now due to cost but if it all works decent ill slowly change over to fuel injection due to no carb jetting and also im trying to get into diesel tuning and also gas motor tuning because of the money you can make in that field.
turbo goes after the expansion chamber on the exhaust to try and help keep it from wanting to spool up and down as the exhaust pulses go out and back in the cylinder. plus one of my ideas will help smooth out the exhaust pulse problem for the turbo and make it think it is a 1 stroke along with introducing fresh air and fuel into the exhaust to be burned by the scavenging cycle helping with the lean at wot problems and also egt issues. basically my design is going to be a constant pressure spooling the turbo like if you just stuck an air hose into the exhaust rather than having exhaust pulses like a normal motor but nothing is going to really be added to achieve this and i havent seen it tried or used before so i cant give up my secret until after it is working for fear of someone else getting to make one work before me. keep an eye out here and there for this topic over the next few months because im going to start building this as soon as i can get some other things taken care of so i dont have to worry about them. within a month i should have all of my engine parts swapped over back into my higher quality engine case and the liquid cooling system working and my bike back up and running as naturally aspirated.
also it may end up going to a diesel fuel type during the process and that would greatly help with some issues of running a turbo. detonation from cheap gas and added upper cylinder lubrication along with the bearings my motor would thank me. ive ran a high comp cylinder before that was 15:1 with a 50:50 gas diesel mix and it ran like a beast no joke. that tank of fuel was the best acceleration and top speed ive achieved from my bike but i dont count it due to the fact it was a 1 time fluke. cylinder temps stayed about 40 degrees cooler and i did over 70 on my bike. according to science diesel only needs a 15:1 compression ratio to ignite and everyone always says ooohhhh glow plugs yo what about those. the cummins runs a 17:1 comp ratio and hasnt needed glow plugs for over 20 years... duramax's also dont need glow plugs unless its below freezing so thats a load of hogwash. ford diesels on the other hand need every bit of help they can get to start. when i make the jump to diesel i plan on using a spare head shaved down a good amount to get my compression up to atleast 16:1 or 17:1 for ease of starting and also added power no reason to change port timing by decking the cylinder base but maybe decking the top of the cylinder would be helpful too. i have lathes at my disposal to do both and a machine shop that would gladly help if i cant manage to do it myself they want to see it too. they built quite a few 2t race bikes in the big motor world along with some dirtbikes and mini quads for their good customers.
my coworker call me petty for wanting a turbo 2t but i tell them they just dont understand. i love my bike and nothing beats peoples faces when they laugh at u at the light and you end up doing a wheelie from a dig and roll smoke on them in the process. or when you pass them because they dont know how to drive the speed limit and your on a moped. add a whoosh and a blow off valve to it and it would be worthless because you cant put a price on that.
