Post by blaq on Jul 5, 2016 21:23:17 GMT -5
Staring @ these wires and blowing fuses all day got me such in a bad mood right now ugh.
Post by blaq on Jul 5, 2016 21:26:13 GMT -5
So the solid black wire goes from the keyswitch to the CDI? if so then cut it, connect the pink to the side going to the keyswitch and the gray wire gets connected to the other black going to the CDI. If you watch video that what he did I did it as well head bang still
Post by arkie on Jul 5, 2016 21:47:16 GMT -5
So I pulled the plug on both ends tied that wire to it but it did nothing nothing changes adding that wire to it and it will remote start, and not remote cut off or anti hijacking This shows the pink wire connected to a black wire and the gray wire connected to a "Blue" wire? ?
Post by blaq on Jul 5, 2016 21:53:37 GMT -5
The blue wire u c is blue and black it was connected to the black and white wire that I connected the pink one 2
Post by arkie on Jul 5, 2016 22:01:55 GMT -5
The only other thing I can think of is to find another power source for your relays. I think when they kick in it may be robbing power from your alarm "brain".
Post by blaq on Jul 6, 2016 17:43:20 GMT -5
Yea I tried that when it was just plug n play b4 I added them I even used the loose wire harness leaving out the yellow wires associated with the lights still nothing anyway back to the drawing board and the store for more fuses
Post by blaq on Jul 11, 2016 22:36:11 GMT -5
Post by Thunder 50 Rider on Jul 12, 2016 8:03:45 GMT -5
spot on arkie, thats what i got from it, and the 4 wires in the circle are most likely in a 4wire bundle, either one cable with the 4 wires in it, or made up like a harness. i have read wiring diagrams before and i was going to say exactly what arkie did
