Post by dude on Apr 12, 2011 11:26:32 GMT -5
I am working on Riva and the starter turns but its not engaging to turn the motor over. What should I look for or replace?
Post by 90GTVert on Apr 12, 2011 11:39:33 GMT -5
I know nothing about that model, but that would generally indicate a bad starter clutch or bendix.
Post by 90GTVert on Apr 12, 2011 11:40:57 GMT -5
Post by reveeen on Apr 13, 2011 16:27:52 GMT -5
And..... as shown by the parts break-down, the folks @ Yamaha are real "dentists" (one small relatively expensive part at a time).
Post by dude on Apr 15, 2011 20:01:12 GMT -5
After rebuilding the carb, pilot jet was clogged. I could turn the motor by hand and then it would turn over by the starter still not starting. I ran a compression it was low. I then checked the vavle clearance it was close on the ex. and almost on the intake. Adj. them and know the starter works fine. Why does the starter work becauce I adj. the vavles? And know it starts and runs great.
Post by 90GTVert on Apr 15, 2011 23:12:34 GMT -5
I get why it would start now, that's common when the valves are out of spec. Why the starter wouldn't work though, you've got me.
