sctrdawg
scooter bum
Post by sctrdawg on Apr 12, 2011 20:07:02 GMT -5
My motofino50QT-10D is just about shit the bed, not fast enough, and is starting to fall apart! I happen to have an engine complete with mounts out of a MF150QT-7, the frame is narrower than the 50 by about an inch and a half so taking some out of each end of the cross member/mount is about all I'll have to do to make it fit. obviously I'll have to remove the mount system for the 50, I think it'll be worth the effort!!I'll need to get a variator,gearbox cover(damaged),belt,counter shaft reduction gear( teeth sheared off),and cvt cover What do you guys think about this?
Post by 90GTVert on Apr 12, 2011 20:16:37 GMT -5
As long as you have metal welding and fabrication skills, you should be able to make it work. When you say the scoot is falling apart, I hope that doesn't mean essential things like brakes and steering etc... If you're gonna go fast, make sure you have the means to stop and steer and ride safely.
sctrdawg
scooter bum
Post by sctrdawg on Apr 12, 2011 20:32:09 GMT -5
oh yeah ! it is just too many miles on the QMB139! i know i could freshen it up but, it just isnt fast enough for me! by falling apart ,i mean the plastic body parts are getting crappy want to swap this in while i still got enough plastic for it to be a sleeper!! my cousin is a journey man welder , he welded the frame when it broke almost completely into and you could drop a dump truck on it and it wont break in that welded area!! He's damn good!! i can do the gutting/cuttingand let him do the welding! any way i think with some performance parts later on it'll be a screamer!!
