Post by Scootrific on May 4, 2017 16:26:21 GMT -5
Today @ work I took time and bleed the front disc brake. Used the one person method, with a plastic 0.5L limonade bottle
Post by Scootrific on May 5, 2017 13:35:56 GMT -5
My future Plans: (A) Plans for 2017Repair/swap plastics and paint Swap front light combo, build and add windshield maybe something else. (B) Plans for 2018Go from 50cc to 90cc (swaping crank, cylinder, camshaft, cam chain) use the 20mm Naraku carb with 90cc or go with 24-28mm
Post by Scootrific on May 6, 2017 3:32:29 GMT -5
Post by Scootrific on May 6, 2017 8:24:51 GMT -5
Today I brought 2 bolts (M6), washers and nuts (These Nuts !!!) for the bolts. Tomorrow, I hope, will cut the 2 broken bolt remains from the seat lock beam and replace them with new M6 bolt and washes. Note! M6 - allmost feels like British Secret Service Mi6
Post by Scootrific on May 7, 2017 14:22:52 GMT -5
I wish, I had a free day to film the American car cruise, but that video is better, that nothing:
Post by Scootrific on May 8, 2017 9:28:30 GMT -5
Today I swapped the front old brake disc and pads to a NG disc and Delta pads. Installed NG disc and Delta pads:
Post by Scootrific on May 9, 2017 17:02:21 GMT -5
Post by Scootrific on May 12, 2017 10:00:45 GMT -5
Yesterday, I noticed, that someting is training my scoots battery. I´m glad, that scoot has the kick-start system, it saved my beacon. I adjusted the intake valve (0.003 inch) and exhaust valve too (0.004 inch). Tried out the new TecMATE Optimate 1 battery charger too over night. AWSOME! Near future, I´m going to do half of my scoots new paintjob.
Post by Scootrific on May 13, 2017 12:50:43 GMT -5
Post by Scootrific on May 14, 2017 14:03:44 GMT -5
Today morning I wanted to continue my prep for paint and fill some holes and remove the front park light, to fill that hole smooth. But I did sleep in at the morning and then I pushed the work forward, to some other time. One of the reasons was the amount of spraycan paints (primer and base white). I brought the primer, base white and clear only 3 pieces.
I think, that only 3 pieces of each, does not cover all the plastic covers, that I plan to paint. So I need to get some plastic primer, and the primer, base white, and clear, 3 pieces more. And also, the base black and neon orange - 2 pieces.
Post by Scootrific on May 16, 2017 16:01:04 GMT -5
Here is some pics about the stuff I brought recently. 4x Clear (need to buy 2 more); 3x Plastic Primer 6x Gloss White base paint 2x Neon Orange paint 1x Heat gun 1x Multi tool 2x packs for sanding 1x Glass fiber putty, 1x Multi putty 3x masking tape 2x Fine line tape 3mm x 55m 2x Fine line tape 9mm x 55m 3x putty Hardener 2x rubber thingys for applying putty
Post by Scootrific on May 18, 2017 15:27:51 GMT -5
Post by Scootrific on May 19, 2017 5:19:19 GMT -5
Today I painted the test panel, to see the 3 colors (white, black and neon orange) combined. Only Neon Orange: The pic with the orange was mage before my paint job vent south. Then I started all over. And all combined (Orange is little bit lighter):
Post by Scootrific on May 19, 2017 10:22:58 GMT -5
Today I went to small ride and noticed that someting is wrong, with my scoots exhaust. 1st tought was the cylinder nuts. I was so wrong: The DB-Killer was gone from the exhaust, so I went and brought new (Sound was like one of the Harley Davidson bike ) :
Post by Scootrific on May 21, 2017 0:28:35 GMT -5
Today, when I took a ride to work, I found my lost exhaust DB-Killer silencer near my home. I took it with me. I will fix and mod it.
