Post by c0m1bws on Apr 18, 2011 18:41:08 GMT -5
Hello ppl i have one problem, which hopefully can be answered on this BEAUTIFUL forum :D I am planinig to buy this www.scooter-attack.com/index2.php but the thing is $MONEY$ costs alot, do you guys know any other method of lifting my rear end high, so it is higher then normal. THANKYOU
Post by jmkjr72 on Apr 18, 2011 18:57:48 GMT -5
Post by 90GTVert on Apr 18, 2011 19:11:30 GMT -5
A longer shock would work also. It would cost more, but some of the adjustable stuff out there is much nicer than stock. Just seems like it would be worth paying extra to not need the adapter and be able to adjust the ride. I think I paid 70 for one and 50 for another. Get an idea of the overall length you want and then search ebay for that length in mm... like say, "275mm shock" or whatever you want.
Post by c0m1bws on Apr 18, 2011 19:14:24 GMT -5
jmkjr72 yes that what i was looking for but also i need a shock it self to be bigger then stock, does any one know how much would it be ? I AM LOW ON BUDGET
Post by 90GTVert on Apr 18, 2011 19:33:16 GMT -5
Get an eye to eye (from centers, uncompressed) measurement of your current shock. Come up with a range. If you search for generic terms like "scooter shock" and look around a bit, sometimes you can find used stuff in great shape really cheap. I got a "lowering" shock, just a shock from a different scoot that met my requirements, for $30 new some time ago. I know when I was on eBay looking for my last adjustable shock not long ago there were quite a few used scooter shocks going real cheap.
Post by jmkjr72 on Apr 18, 2011 19:49:00 GMT -5
the thing you are going to run into if you go with a long shock and a 60mm or even a 40mm spacer is you wont be able to use the center stand and you will end up with other clearance issues what kind of scoot if its a zuma or bws about 40mm is all you can add without issues
Post by c0m1bws on Apr 18, 2011 20:20:38 GMT -5
jmkjr72 u have BWS? if u do, do you have any of this staff and 40mm i think would be the best, whats that shock called again? THANK YOU GUYS SOOOOOOOOOOO MUCHHHHHHHHHHHHH
Post by c0m1bws on Apr 18, 2011 20:23:12 GMT -5
and other thing i though sitting in front of my pc and watching tunning scooter shows, i saw those handle bars called "DOWNHILL" do you know any store that has them cheap? cuz i would rather buy that then a shock
Post by jmkjr72 on Apr 18, 2011 20:29:14 GMT -5
i have a zuma so its the us version of the bws i dont have the lift block on mine i put it on one i worked on this is the one i installed www.spmotostore.com/product_p/str-200.40-p.htmi think i had to to just a bit of clearanceing to get it to fit nice but it wasnt much work
