Post by chacham on Aug 31, 2016 8:38:13 GMT -5
Okay, i think i am going to buy that spring and see what happens. Any ideas about the pin though? The pin that goes on the end of the rod. Searching for gy6 50 main stand pin or gy6 50 center stand pin doesn't seem to be working.
Post by pinkscoot on Aug 31, 2016 13:47:31 GMT -5
The pin on the stand or the bolt on the motor:
Post by chacham on Aug 31, 2016 14:13:39 GMT -5
The pin that holds the rod on top from slipping out.
Post by pinkscoot on Aug 31, 2016 19:43:42 GMT -5
Check your case and see if there's a bolt hole there.
Post by chacham on Sept 8, 2016 8:23:12 GMT -5
Yay! We got it in.
The spring came in on Tuesday and we got to it this morning. A little hammering got the bolt through, as it was not perfectly straight. A nail is being used instead of the cotter pin, which we may replace soon. (I do not know what size to get.)
To get the spring on, he used a screwdriver as a lever, and once the spring was down far enough, it was coaxed to slide into place.
Thank you for all the help! Next to work on the low beams, but that post comes later.
Post by pinkscoot on Sept 8, 2016 9:19:03 GMT -5
Glad we could help.
