Post by 'O'Verse on May 21, 2017 20:19:24 GMT -5
What kind of pizza?
Post by spaz12 on May 21, 2017 20:43:00 GMT -5
Are you just running the HiT clutch and bell? Maybe it's just a broken spring and it locked in. Hurry up and fix it. Already fixed and I'm running the Polini 2G clutch right now. You'd probably never guess what happened. I've never seen it happen. Anyway, the large nut that holds the clutch to the TD spun itself off and so the torque spring was pushing the clutch up against the outside of the bell. As soon as I took the small nut off to remove it all, the clutch and bell shot off. Sooo weird! Got super lucky that it didn't F off those fine threads on the TD. The Dr Pulley bell is a bit burnt up so I'll have to get a new one pretty soon
Post by spaz12 on May 21, 2017 20:44:09 GMT -5
Post by 'O'Verse on May 21, 2017 21:07:58 GMT -5
Hey Dominoes stepped there pizza's up a long time ago. There actually good!
Post by tsimi on May 21, 2017 21:41:15 GMT -5
Relieved to see that it didn't cause any real damage. How is it possible for that nut to come loose? How do you usually tight that nut?
Post by spaz12 on May 21, 2017 22:25:56 GMT -5
Relieved to see that it didn't cause any real damage. How is it possible for that nut to come loose? How do you usually tight that nut? I use an impact gun to tighten that nut. I put some loctite on it this time though.
Post by spaz12 on May 21, 2017 22:54:26 GMT -5
Gonna go take er for a night run to see how she does. I'll see how the Strip is looking. Maybe I can travel the whole thing?
Post by tsimi on May 21, 2017 23:15:32 GMT -5
I don't see any marking on your variator. You don't check how far the belt travels?
And does AAA work also at late hours?
Post by spaz12 on May 22, 2017 0:30:06 GMT -5
I don't see any marking on your variator. You don't check how far the belt travels? And does AAA work also at late hours? I put sharpie mark on it a while ago and I guess it just wore away since the belt rides all the way out. AAA works 24 hours a day in the good old USA.
Post by Lucass2T on May 22, 2017 1:15:28 GMT -5
Relieved to see that it didn't cause any real damage. How is it possible for that nut to come loose? How do you usually tight that nut? I use an impact gun to tighten that nut. I put some loctite on it this time though. Thats scary! You got a lot leaverage with those fine threads, don't tighten them like you tighten normal threads! I always tighten that one by hand.
Post by spaz12 on May 22, 2017 1:33:29 GMT -5
I use an impact gun to tighten that nut. I put some loctite on it this time though. Thats scary! You got a lot leaverage with those fine threads, don't tighten them like you tighten normal threads! I always tighten that one by hand. Damn, I usually zap it a couple of times with the impact.
Post by spaz12 on May 22, 2017 2:26:39 GMT -5
I took it for another run tonight and she ran great. Made it down to the Strip and even a bit further than the last time, but caught up to a bunch of traffic that I had no intentions of sitting in. Anyway, had some kid in a SUV ask me if it was a turbo
Post by tsimi on May 22, 2017 5:39:16 GMT -5
Good to see that she's back, like there was never anything wrong with her.
Post by spaz12 on Jul 2, 2017 16:43:20 GMT -5
Scooties new home
Post by PIG on Jul 2, 2017 16:47:00 GMT -5
Good for you man, that's awesome!
