Post by mauibird on Jan 3, 2017 18:15:56 GMT -5
Post by birdman on Jan 3, 2017 23:53:16 GMT -5
Very nice so far. I always lurk your builds, you do some sick stuff. Thats a variated af05?
Post by mauibird on Jan 4, 2017 2:49:10 GMT -5
Very nice so far. I always lurk your builds, you do some sick stuff. Thats a variated af05? Thanks! No, non-variated. Just a little neighborhood cruiser. couldn't leave her bone stock though.
Post by mauibird on Jan 4, 2017 3:15:42 GMT -5
Post by mauibird on Feb 2, 2017 17:13:45 GMT -5
Got her running, took her around the block and soft seized her twice. Had nice power when getting on it, but when i let off the throttle it seized. So I got carb issues. Can't get enough out of the stock carb, it only has a tube for the pilot jet. Not adjustable. So I found a random intake on Treatland that would convert my carb to a spigot style connection, same size as the phbg carbs, and I pulled the trigger on a Polini 17.5mm cp Carb.
Post by mauibird on Feb 2, 2017 17:15:36 GMT -5
Random Carb adapter
Post by mauibird on Feb 2, 2017 17:24:44 GMT -5
Post by oldgeek on Feb 2, 2017 17:27:11 GMT -5
You need any stuff for the motor? I got one laying out back.
Post by Senna1Rossi on Feb 2, 2017 17:29:30 GMT -5
Wow, lots work on this bad boy. Good job
Post by mauibird on Feb 2, 2017 17:29:55 GMT -5
Post by mauibird on Feb 2, 2017 17:32:45 GMT -5
You need any stuff for the motor? I got one laying out back. I'll let you know, thanks. I might need a stock exhaust to pass our new safety check program. Cant be over 100 decibels at half throttle. I might barely fail with my MLM exhaust. I tossed my stock exhaust before I knew the law was changing. It was pretty toast anyways
Post by eclark5483 on Feb 2, 2017 18:38:38 GMT -5
I have a ported intake for it if your interested. You could also put a Kitaco intake on it as well. Have the reed cage ported too. You can really get that sucker hopping if you want. Look at my Spree build for ideas.
Post by niz76 on Feb 2, 2017 19:37:35 GMT -5
Sweet little neighborhood cruiser! I've had my Polini CP carb for a while now and love it! I did drop some jet sizes from the carb before but it's hard to compare since I went from a Mikuni TM24 to a CP 21...
Post by eclark5483 on Feb 2, 2017 23:08:59 GMT -5
My AF05 Spree is running the CP21 Polini with Kitaco intake and ported SB50 reed cage. I'm only using the stock jets that came with it, thinking I might need to go a bit higher, but the my A/F mix is perfect. Might try later this spring and see what it does. I'm able to hit just a tad hair over 11,000rpm.
Post by eclark5483 on Feb 3, 2017 2:01:42 GMT -5
Here's that Kitaco intake I'm talking about japan.webike.net/products/373376.htmlPort that out with some ported reeds, ain't nothing gonna hold you back. Dyno testing showed a huge performance gain over a ported SB50 intake. Plus, no need for a CP adapter, all you need is a coupler for an almost perfect match. Here's what it looks like setup on my Spree And here is a pic of the ported reed cage:
