Post by turbotype1 on Oct 5, 2016 14:58:33 GMT -5
So I built up a Ruckus with a Zuma motor for my wife to ride. I put an Aerox front end on it and wanted to do a rear disc conversion. I bought a R&D caliper bracket which needed a little "machining" done to it..... The trench was already there... it just needed to be deeper. Next, I had to "machine' down the case to fit the caliper bracket...As well as locating/drilling the holes Next came " The Hub"..... The whole time I thought that an Aerox hub would slide right on so I didn't give the hub/disc a thought.... Until now! I had an Aerox hub, but, The Aerox uses a smaller spline.... :doh: So the search was on for something that I could make work. I found out ,through some members on here,(thanks Goshi,Spaz) that a CPI GTR50 had disc rear brake and shared the same spline with the Zuma. I found one over the pond that came with the disc as well thankfully. So the hub fit the splines, but , the offsets for the wheel surface as well as the disc were off. Thankfully the CPI hub was thicker than the Aerox hub so I was able to turn it down to match the Aerox dimensions. Disc side Wheel side Had to remove some splines as well One last thing.... The bolt pattern for the disc was off , so I had to use the CPI disc. The CPI disc was too big so I had to turn that down to the diameter of the Aerox Finally finished and it works the balls.... Would I do it again??? Probably not!! I'd buy another set of Aerox cases with final drive and start from there.....
Post by ryan_ott on Oct 5, 2016 16:11:04 GMT -5
Very nice. A lot of effort went into this. I wish I had rear disc...
Post by gsx600racer on Oct 5, 2016 18:46:47 GMT -5
Nice and tidy conversion. Great job.
Post by spaz12 on Oct 6, 2016 0:06:28 GMT -5
Another job well done. Can't deny that it's pretty damn cool to have something that most people don't, even if it is just a disk brake. Love it.
Post by tsimi on Oct 6, 2016 1:38:38 GMT -5
Well done! Bravo! I wonder how much did it cost you? A hub ain't cheap.
Post by turbotype1 on Oct 6, 2016 11:37:23 GMT -5
Well done! Bravo! I wonder how much did it cost you? A hub ain't cheap. Thank you.... It cost me $80.00 US for the hub and disc.
Post by moofus02 on Oct 6, 2016 11:53:25 GMT -5
Well done! Bravo! I wonder how much did it cost you? A hub ain't cheap. Thank you.... It cost me $80.00 US for the hub and disc. A friend of mine did the conversion on a clone a few years ago. He said the axle was longer on the disc brake bike. I guess I know why now
