Post by greggkinney on Oct 6, 2016 18:42:23 GMT -5
Anybody know if the Zuma50 drive face or contra spring will work on a qmb? Or minerilla parts? Found a hook up on couple cheap parts if they fit
Post by birdman on Oct 6, 2016 19:45:41 GMT -5
139qmb no 1e40qmb yes most likely as long as the crank splines are the same.
Post by just1artist on Oct 7, 2016 7:19:51 GMT -5
Some Honda parts fit, I have more than a few Honda metro parts on the putt-putt (1p39qmb) just have to know specs...
Post by badpumpkin on Oct 9, 2016 22:00:27 GMT -5
Time to get a micrometer.
Post by 90GTVert on Oct 10, 2016 10:24:28 GMT -5
Some parts for these that I've received come labeled "Dio", such as contra springs and clutch springs and IIRC an NCY torque driver that I had was labeled that way. I'm not really sure if the whole CVT will swap in, but parts of Honda Dio CVT seem to.
Post by jkeney on Oct 10, 2016 12:36:15 GMT -5
Kymco CVT parts are interchangeable. I have not confirmed that the gear box uses same gears and bearing, but that is what I have read. The variator and clutch are 100% compatible. I have also used CVT parts for the Dio, but I only used clutch and torque springs so I can't say what else is.
Post by greggkinney on Oct 10, 2016 17:23:32 GMT -5
I've also noticed also a lot of parts say fit qmb139 dio sym and kymco. I'm running a stock kymco 2t varie and clutch bell on my qmb Tao Tao rite now. I've passed on trying the parts in question and purchased legit qmb parts. Thanks for your help once again guys
