phatmanxxl
Post by phatmanxxl on Oct 19, 2016 13:36:35 GMT -5
Got it all off but the air vent on top of the valve cover....do I block it off or what? Air and oil comes out of it, I put the hose near the intake but it bogs down the engine. I've googled around but couldn't find a solid answer if this vent can be blocked off or not, I've read about vapor locking and some say reroute it to the airbox, which I don't have.
The hoses were getting dry rotted and vacuum leaking all over so I'd rather just pull the whole thing out instead of replacing a mess of hoses. All I need to replace now is the hose that goes from the intake manifold to the fuel petcock.
I just need some good advice on what to do with the valve head vent.
Post by badpumpkin on Oct 19, 2016 16:38:03 GMT -5
A,leave it open and loop a hose over next to your carb/gas drain hose, but leave it open. B,block it off but first get a oil filler venting unit. You have to let the pressure inside the engine fluctuate and or vent.
Post by jeff84 on Oct 19, 2016 17:30:35 GMT -5
if you really want your crank bearings to fail you can block it off, otherwise leave it open. you can rout it into a catch can if needed so you don't get oil everywhere.
Post by niz76 on Oct 19, 2016 19:25:22 GMT -5
If Fox were still here, he'd show you a pic of a long hose zip tied to and running up the frame so that it's higher than the engine. This lets the oil travel up in the tube/hose while venting and just drain back down back into the engine/valve cover. IIRC he put a small air filter/fuel filter at the end of the hose so it can still breath but not let crap get it...
R.I.P. Fox.
Post by niz76 on Oct 19, 2016 19:30:34 GMT -5
Here ya go. Here's the pics that Fox used to post for this subject:
phatmanxxl
Post by phatmanxxl on Oct 19, 2016 22:38:35 GMT -5
I fashioned a oil catch can, with a fuel filter for a vent but I like niz illustration too. Thanks guys. A guy from the Ruckus Facebook page showed me this: ebay.com/itm/182026691937
Post by gsx600racer on Oct 20, 2016 0:47:01 GMT -5
Post by 90GTVert on Oct 21, 2016 13:36:44 GMT -5
