Post by greggkinney on Jan 2, 2017 2:58:01 GMT -5
Beautiful, all I can say
Post by drc174 on Jan 2, 2017 21:48:32 GMT -5
Alright, so the funny angle is fixed, it is hooked up and throttle cables are done. WHAT. A. BITCH. This thing needs all the fucking plastics taken off to even remotely have access to anything. Not a fan. Anyway, leak down test tomorrow if i can throw together a kit and the time to fire it up once I figure out how to hotwire it, because my friend forgot to give me the spare key and I broke that one... (No folks, I DID NOT STEAL IT, just waiting on the spare key) I really really really like how straight it is.
Post by spaz12 on Jan 2, 2017 22:15:53 GMT -5
PM'd you.
Post by greggkinney on Jan 2, 2017 22:42:47 GMT -5
Is I a 5 wire switch? I have a kymco people that the p.o had hot wired because the key was broke off in the switch. I've changed the switch but the p.o had removed the switch plug end from the harness and i unhooked the wires he had spliced without thinking lol had it 8 months and can't find a diagram anywhere. Good luck and if you figure it out how about sharing a little knowledge
Post by drc174 on Jan 3, 2017 20:27:21 GMT -5
DId a leakdown test today, have some leak issues around my bracket, so i have to redo some of the gasket stuff. I just got to get a proper milling head and flatten the drill I did over there, it is rather.... poopy.
Post by drc174 on Jan 3, 2017 23:25:00 GMT -5
Fixed the leak under the block, seems to come from the intake now. Letting rubber gasket dry over night, hopefully it will be good by tomorrow.
issue I have is a little dremel nudge accident that happend, I may have to plan the thing.
Post by birdman on Jan 3, 2017 23:56:26 GMT -5
Im just going to put this post here so I can follow it in my "participated" tab.. Im a fan of the Super8s
Post by spaz12 on Jan 4, 2017 13:24:32 GMT -5
Im just going to put this post here so I can follow it in my "participated" tab.. Im a fan of the Super8s I bookmark a lot of threads myself, because if a thread isn't posted to for a while, you stop getting notifications in the participated tab.
Post by drc174 on Jan 4, 2017 16:59:59 GMT -5
The intake is sealed, had to cut off a old piaggio reed manifold i had to make a bracket. The rear seal apparently tends to have issues on the poaggios which is why the reed valves have an extra ridge of plastic. Everything is super siliconed up. Not my prettiest work but the kymco shall fly with that 20
Now to button the plastic on an get the keys
Post by drc174 on Jan 5, 2017 21:25:37 GMT -5
Fitted a choke on there (Note from back in the 00's, PHVA Chokess fit with minimal manipulation on VM20's) Plastics are back on, and there is enough clearance with that seat on. Gotta get a jerry can full of gas, the keys and then hope for less snow so I can get to jetting. Also, I should put the exhaust back on...
Post by drc174 on Jan 27, 2017 1:11:34 GMT -5
Alright, finally got a little bit of time. This older footage, more to come in the next day,a ctually had enough for a few videos! Come see my fuckups.
Post by drc174 on Jan 29, 2017 12:04:24 GMT -5
Simple clutch install on Kymco and 8 minutes of rambling and a beer. Enjoy:
Post by 2TDave on Jan 29, 2017 12:54:18 GMT -5
I've got a friend that had one. He had your same setup with an Arechee 19mm and it went right in. That bike ran in the low 60mph range with just that.
Post by drc174 on Feb 22, 2017 23:09:59 GMT -5
Runs and is leak tested! Just fired up, responds great, have not ridden it yet. Going to post a ahort video in just a few minutes
Post by drc174 on Feb 23, 2017 0:47:03 GMT -5
Alright,
here it is, also stay tuned for the shit that's about to come in 2017
