Post by pinkscoot on Oct 20, 2016 19:09:33 GMT -5
While searching CL I found this 2006 Zuma. My understanding is they didn't import them in 2006 or 2007. Can anyone identify the year of this one.
Post by spaz12 on Oct 20, 2016 19:32:24 GMT -5
Post by pinkscoot on Oct 20, 2016 19:33:56 GMT -5
I may go look at it tomorrow. The price sounds good and it looks to be in good shape.
Post by spaz12 on Oct 20, 2016 19:36:12 GMT -5
I may go look at it tomorrow. The price sounds good and it looks to be in good shape. I'd go buy it tonight, not tomorrow
Post by pinkscoot on Oct 20, 2016 19:37:26 GMT -5
Its an hour away and I'm working until 10pm. I just texted him, I'll wait to see.
Post by pinkscoot on Oct 21, 2016 20:04:18 GMT -5
I went ahead and bought it. It was in pretty rough shape so I offered hip $100, he almost cried so I offered $150 and he was okay with that. It is a 2005 with 20,000 Mi/KM on it. Its missing several pieces of plastic. The front end is good and the back end has a number of zip ties. He was told by the PO it had a BBK on it. That the oil pump doesn't work. It has a new front knobby tire and a worn back street tire. For some reason he couldn't explain he took the starter off of it. I'll know more when I get into it. Here are some pictures:
It looks like it will be a fun project and will be a nice addition to the family.
Post by spaz12 on Oct 21, 2016 20:21:23 GMT -5
Nice fixer-upper. With just an Athena basic and maybe a Yasuni R you'll be dustin those pesky 150's
Post by pinkscoot on Oct 22, 2016 17:51:03 GMT -5
I had an hour or so to look at the Zuma. I got the kickstand on and I don't think its for that scooter, there was no where to hook the spring. It was also bent up and hit the CVT when up. I managed to get scoot on it. Checked compression 90psi added oil and 150psi. Rings are shot. I replaced the spark plug cap and got it to start and it sounded like a box of bolts in the crankcase. Turned it off and did some more snooping. I was told it had a BBK on it, hahaha they never do, its the stock cylinder and head. Discovered the noise when running, the crank is gone. I got the same flywheel movement I had with the TGB.
So I need a new crank, top end, exhaust is in bad shape, I'm sure the CVT needs work. I need to decide what kind of project this will be.
Post by ryan_ott on Oct 22, 2016 18:13:41 GMT -5
Hyper race
Post by oldgeek on Oct 22, 2016 18:37:16 GMT -5
If you decide to flip it, let me know. I have a stock zuma top end somewhere that ran fine when I took it off.
