Post by 'O'Verse on Jan 3, 2017 21:10:29 GMT -5
6 pack! 14 gauge green, yellow, red, blue, black, and white.
Post by 'O'Verse on Jan 5, 2017 17:54:46 GMT -5
Clear braided hose showed up today.
Post by niz76 on Jan 5, 2017 19:56:27 GMT -5
I made a down-n-dirty harness for my "off road scoot" condensed down to only kill switch, horn, and headlight. I may add a charging circuit/rectifier regulator for a battery and e-start later on. Lemme know if you run into any troubles wiring her up while it's still fresh in my mind.
Post by 'O'Verse on Jan 5, 2017 20:54:43 GMT -5
I made a down-n-dirty harness for my "off road scoot" condensed down to only kill switch, horn, and headlight. I may add a charging circuit/rectifier regulator for a battery and e-start later on. Lemme know if you run into any troubles wiring her up while it's still fresh in my mind. Yes sir thank you. Yeah I'm just going kill switch and some type of cluster. Either stage 6 or Vapor trail tech. Most likely stage 6. I will definetley be needing the Niz skills soon.
Post by drc174 on Jan 5, 2017 21:32:54 GMT -5
I got that Stage6 cockpit thing I can send over for half off.
Post by 'O'Verse on Jan 5, 2017 23:41:34 GMT -5
I got that Stage6 cockpit thing I can send over for half off. Black and white?
Post by drc174 on Jan 6, 2017 6:24:48 GMT -5
Orange -.-
Post by 'O'Verse on Jan 11, 2017 0:04:10 GMT -5
Called scootertuning today asked them what the progress was on the RC-One. They emailed me back saying the engine has shipped from Italy today. So I'm assuming it'll be here within the next couple of weeks. Very thorough those guys at ST.ca. You ask them a question and there on it. Except for there obvious 7-10 day promise on there website. I'm pretty impressed with there over all customer relation skills.
Post by spaz12 on Jan 11, 2017 13:09:10 GMT -5
They need to put a rush on this sh*t. I'm dyin to see what this motor looks like.
Post by 'O'Verse on Jan 11, 2017 13:40:18 GMT -5
They need to put a rush on this sh*t. I'm dyin to see what this motor looks like. Yeah... me to. Almost painted the rims that Roost blue. In hopes of roosting out the jog later. White frame, black gloss body, roost blue rims to match the cylinder pipe combo. I'm sure the Malossi will look just as good after I paint the cases.
Post by 'O'Verse on Jan 12, 2017 0:57:07 GMT -5
Couldn't resist. E-mailed the powder coaters. Having them re paint the rims Roost blue. Or the closest thing we could match it to that there company had. RAL 5002. Extra $75 for the re paint but I think it'll be worth it in the end. We'll see. Also ordered a KN triple tree for $150. Aluminum For a 3YK. So we'll see if I have to machine the stem down.
Post by 'O'Verse on Jan 12, 2017 22:25:12 GMT -5
Post by Lucass2T on Jan 13, 2017 12:21:37 GMT -5
Ooh that triple tree is very nice! Where did you get it from??? I myself am silently looking for a lightweight tree to replace the heavy cast iron one from my axis.
Post by 'O'Verse on Jan 13, 2017 12:30:03 GMT -5
Webike Japan. Decent price. But no dimensions or specs. Picked it up in hopes I don't have to have it machined down. japan.webike.net/products/2053755.htmlEDIT: I'll post measurements when I get it.
Post by Lucass2T on Jan 13, 2017 15:28:05 GMT -5
EDIT: I'll post measurements when I get it. That would be GREAT! Im especially interested in the stem dimensions since they can vary between a drumbraked and diskbraked axis (im pretty sure the jog uses the same stems/forks/tripletrees like the axis). So yeah, that would be great if you could take some measurements!
