Post by tsimi on Apr 29, 2018 18:05:33 GMT -5
Post by 'O'Verse on Apr 29, 2018 18:06:57 GMT -5
Exactly... he’s already on point with his skills. You’ll find out. Just because his bike in the video is producing 35hp. Don’t think it’s not gonna happen to you at 25hp..... your still gonna have trouble keeping your front wheel on the ground. By no means am I trying to brag or exaggerate. I’ve already come to terms with not being able to Gun it all out from a dead stop.
Post by drc174 on Apr 29, 2018 22:30:39 GMT -5
I think there is a lot to gain by focusing a bit more in the CVt and clutch. You could launch harder, that wheels gotta be trying to come up all the time. Also, with setups like this, clean your CVt well and often, potentially sand/blast the surface often That’s the thing. I’m babying the throttle because it’s launching to hard already. There’s physically no way I can just Gun it from a stop. You need balls so big that the weight keeps the front down!
Post by 90GTVert on Apr 29, 2018 23:01:30 GMT -5
I wouldn't expect much out of this, but it's easy enough... try adjusting your rear shock and see if you can make it any better.
Some drag racers will rotate their hbars so they sit far forward and down farther. Prob not worth the effort on a nice looking bike that's not primarily a drag racer.
Post by tsimi on Apr 30, 2018 8:53:06 GMT -5
'O'VerseI am about to place an other order overseas for small bits and pieces and was wondering about the water temp sensor you got. That's a Koso 16mm right? Did it come with the white plug sensor or did you swap the sensor out? All the pics i see show the sensor cable with the black 3 pin plug but i need a 2 pin white plug sensor.
Post by 'O'Verse on Apr 30, 2018 12:38:54 GMT -5
I wouldn't expect much out of this, but it's easy enough... try adjusting your rear shock and see if you can make it any better. Some drag racers will rotate their hbars so they sit far forward and down farther. Prob not worth the effort on a nice looking bike that's not primarily a drag racer. Probably could loosen the rear up a bit. It's pretty stiff back there. Maybe some aftermarket foot pegs. Towards the center of the bike. Kinda push back on while I'm leaning foward. A jog seat just wasn't made for wheelies at all.
Post by 'O'Verse on Apr 30, 2018 12:44:26 GMT -5
'O'Verse I am about to place an other order overseas for small bits and pieces and was wondering about the water temp sensor you got. That's a Koso 16mm right? Did it come with the white plug sensor or did you swap the sensor out? All the pics i see show the sensor cable with the black 3 pin plug but i need a 2 pin white plug sensor. I don't know if I've seen a 3 pin. I think the koso is just a 2 pin. Post some pics of a 3 pin. I think the Malossi cylinder/head and Stage6 cluster each came with an extra plug each. I can run out to the garage and look around for you. Snap a couple pics. I can tell you that the Stock Malossi, Stage6 cluster, and my koso gauge were all compatible.
Post by tsimi on Apr 30, 2018 17:35:19 GMT -5
Not sure myself if it is a 3 pin but the plug is black and not white. My Koso gauge has all white plugs so my guess is if i want to use something like that i most likely have to swap out the sensor to a white plug type? If you find time can you snap a close up pic of that water temp sensor of yours? Especially the connection. Thx. These here are my plugs I have. The white one is the CHT that I bought recently and the two black plugs are the ones that come from the gauge. Does your water temp sensor plug fit the black plugs of mine?
Post by 'O'Verse on Apr 30, 2018 18:49:46 GMT -5
Couldn’t find the stage 6 box. It’s probably tucked away inside another box. So I did you one better. Spliced some heat shrink to get you the pic. Looks like a 2 prong white plug on both. Koso sensor and from the stage 6 cluster. So I think in the pic I posted of the koso sensor the plug comes with its own heat shrink cover. You would think that koso’s gauges and sensors would be compatible Id try plugging the Black into the white. Unless it’s an obvious mismatch. If the plugs match but there’s some play in between the plastic housings just heat shrink it tight.
Post by tsimi on Apr 30, 2018 19:02:59 GMT -5
Thanks overse. The black female plug on the sensor of your pic above looks different and that is why i am unsure. postimg.cc/image/bnmng655p/But in your 2 pics you just posted the plug is white. If it doesn't fit i have to place another order overseas for just one sensor and shipping is a bitch.
Post by 'O'Verse on Apr 30, 2018 19:03:30 GMT -5
Not sure myself if it is a 3 pin but the plug is black and not white. My Koso gauge has all white plugs so my guess is if i want to use something like that i most likely have to swap out the sensor to a white plug type? If you find time can you snap a close up pic of that water temp sensor of yours? Especially the connection. Thx. These here are my plugs I have. The white one is the CHT that I bought recently and the two black plugs are the ones that come from the gauge. Does your water temp sensor plug fit the black plugs of mine? Hard to get a feel of the actual plug size from a pic. But It does look like the plug you bought(white)is a little bigger than the blacks.
Post by tsimi on Apr 30, 2018 19:06:37 GMT -5
The plugs in my pics black and white are a perfect fit but the female black plug i see on that water temp sensor looks totally different. More like hard square shaped.
Post by 'O'Verse on Apr 30, 2018 19:09:55 GMT -5
Thanks overse. The black female plug on the sensor of your pic above looks different and that is why i am unsure. postimg.cc/image/bnmng655p/But in your 2 pics you just posted the plug is white. If it doesn't fit i have to place another order overseas for just one sensor and shipping is a bitch. Well buddy I'm absolutely sure I have another sensor somewhere. I can dig around for it more tomorrow. And then just send it to you. I'm sure one sensor in an envelope shouldn't be more that a couple bucks to Japan. Edit: cancel that Tsimi. Looks like I used that Malossi head temp plug in my koso sensor. That's why it's white.
Post by tsimi on Apr 30, 2018 20:09:34 GMT -5
Thanks for the help overse. Now I know what I need to order. The additional white plug sensor doesn't cost much so I add that to the order just in case.
Post by 'O'Verse on Apr 30, 2018 20:20:56 GMT -5
Thanks for the help overse. Now I know what I need to order. The additional white plug sensor doesn't cost much so I add that to the order just in case. Your welcome. You know you got it like that with me.
