Post by cwazywazy on Dec 2, 2016 19:51:18 GMT -5
I bought another Sunny style GY6 50. This marks my third Sunny and fourth scooter. (The $20 Yamaha is still around, a buyer bailed on me today.) I paid $52 for it, non running. Swapped in a good battery and put in some gas. Would only run on starter fluid so I did a compression check and got 55PSI. Mind you, this is with a China gauge. (I got 135PSI with it on my Peace.) I guess it's time to start the fun again. First thing will probably be two swap in a 50mm kit I have on the shelf.
Post by cwazywazy on Dec 2, 2016 22:38:18 GMT -5
Also I'm pretty sure I saw old gum in the gas tank.
Post by 190mech on Dec 3, 2016 4:49:39 GMT -5
Did you check the valve clearance?
Post by cwazywazy on Dec 3, 2016 11:27:05 GMT -5
Checked valve clearance, it's fine. It's clearly overdue for an oil change though.
Post by cwazywazy on Dec 4, 2016 13:40:05 GMT -5
Took the engine apart, looks like there's a little bit of scoring on the piston. While I was messing with my old 50mm kit I noticed that the piston I took out of this scooter is too small for the stock jug from my old Peace.. I measured the bore and it's about 43mm.. What does that mean? Unfortunately, I can't find the piston for it.
Post by cwazywazy on Dec 4, 2016 13:44:26 GMT -5
Where can I buy just piston circlips and dowels? I need one for the 50mm and can't find any that work.
Post by 90GTVert on Dec 4, 2016 13:50:40 GMT -5
Post by cwazywazy on Dec 4, 2016 14:20:49 GMT -5
Got the old dowels out and bent a circlip to shape. Almost done with reassembly.
Post by gsx600racer on Dec 4, 2016 16:18:11 GMT -5
Got the old dowels out and bent a circlip to shape. Almost done with reassembly. Its not advisable to re-use bent circlips. As inexpensive as they are its cheap insurance to get new ones vs using the old ones and running the risk of it costing you more down the road. Unless you just going slap it together and flip it and and have it blow up with the next owner.
Post by cwazywazy on Dec 4, 2016 16:22:25 GMT -5
Well, the point is to see how well it runs before I decide to keep it or not. If I keep it, I'll be getting a 52mm and better head.
