Post by 2strokd on Nov 2, 2009 8:17:33 GMT -5
Heres a case leak tester i made for cheap. I had most of the stuff already but the rest is easy to get at about any parts or hardware store for under $15 or $20. I had the hose and y fitting, other fittings, and hand pump, all i needed to buy was the gauge and plug, i got those for under $10. Now i just need to pull my exhaust and carb, put the piston at BDC, and put the plug into the ex. and the adapter into the intake. Pump the tester to 6psi and make sure there isnt any bad leaks at first. If it seems good and sealed leave it alone for 5 to ten minutes. When you return you should still see 6 psi on the gauge, if not pump 6 psi back into the crank case, then spray soapy water around all mating surfaces and look for bubbles. Bubbles equal leaks, leaks equal poor running or an erratic hard to tune motor that may lean out at any time causing damage.
Post by 90GTVert on Nov 2, 2009 8:29:27 GMT -5
Sweet. Pretty simple setup, and cheap to boot. I don't really need one right now, but I might just make one anyway.
Post by 2strokd on Nov 2, 2009 9:07:43 GMT -5
Yea, pretty simple and cheap . Im gonna make some adapters for different intakes and exhausts. I think this would be a good thing to use after assembly of a new top end or after putting the case back together. Its peace of mind knowing there isnt a leak. I hate leaks!
Post by 90GTVert on Nov 2, 2009 10:30:41 GMT -5
Yeah. It sure would be nice knowing if there was a problem before installing a newly built engine and wondering why it won't run well.
Post by 190mech on Nov 2, 2009 19:21:24 GMT -5
A needed tool for a serious 2stroker,Yamaha's were bad about a leaking crank seal on the ignition side causing lean conditions/ fried pistons,etc.I should have made one 30 years ago!!
