Post by niz76 on Jan 3, 2017 20:00:16 GMT -5
If it's happening in all temps it could simply be overly rich at idle. Try opening the filter cover a crack to introduce more air (which will lean it out)- might need to remove a couple screws from it and loosen a couple other then jam something in there to keep it open a crack. If it solves the issue you know you're too rich at idle!
Post by dan50 on Jan 3, 2017 22:49:35 GMT -5
Neat trick Niz76. I'll have to remember that one.
Post by thxcuz on Jan 3, 2017 23:17:37 GMT -5
Just wondering. My fuel filter looks a little grody. Could be starving for fuel maybe?
Post by niz76 on Jan 4, 2017 4:12:34 GMT -5
If it were starving or lean it would probably run better at first while the enricher is still engaged...
Post by dan50 on Jan 4, 2017 11:42:52 GMT -5
Change the fuel filter anyway. Best to keep a clean one on your scoot.
Post by mrhooper on Jan 8, 2017 22:34:00 GMT -5
It sounds like it may be a bit lean.
