duh
Scoot Junior
Post by duh on Jan 9, 2017 11:20:53 GMT -5
i recently purchased a 49cc chinese scooter for a whoppin $100. only bad thing is i jave no idea what kinda scooter it is and the VIN number only indicated it was built in 2011 its a cixi no make or model. the VIN is LJ5LT8036B1070963. ive sent a few emails to a lady who's email has come up when searching for 2011 cixi scoots. ive enclosed a few pictures: any help would be appreciated.
Post by 90GTVert on Jan 9, 2017 13:02:13 GMT -5
Luckily, it doesn't matter a whole lot what the make and model is. With Chinese scoots, they're built in a handful of factories and then re-badged/re-branded tons of times. You mostly need to know the type of engine that you have and the body style to get parts. From what I can see, it looks like you've got the 139QMB 4T engine. That one is the most common these days and parts are usually pretty easy to find. Check out chassis # 6 here : www.scrappydogscooters.com/CHASSIS_PARTS.html
Post by 90GTVert on Jan 9, 2017 13:04:02 GMT -5
Post by Elektrey on Jan 9, 2017 18:32:27 GMT -5
I REALLY like that style of scoot
excellent choice, it looks great!
Post by niz76 on Jan 9, 2017 20:26:48 GMT -5
duh
Scoot Junior
Post by duh on Jan 10, 2017 15:45:22 GMT -5
that's pretty spiffy what ya did. the top priority i have on mine is finding the plastic piece that the seat attaches to. my seat was ripped off.
Post by pinkscoot on Jan 10, 2017 21:22:35 GMT -5
The hinge side? They usually are part of the seat bucket on Chinese scoots.
duh
Scoot Junior
Post by duh on Jan 11, 2017 6:53:31 GMT -5
i found that link on ebay, from scrappy. shippings more than the item tho. would it be easier to get that, or glue the bracket onto the piece i currently have? link
duh
Scoot Junior
Post by duh on Jan 11, 2017 8:23:38 GMT -5
i just can't for the life of me find that one. would it suffice the one off ebay?
wk360
Scoot Junior
Post by wk360 on Feb 11, 2017 10:26:57 GMT -5
Luckily, it doesn't matter a whole lot what the make and model is. With Chinese scoots, they're built in a handful of factories and then re-badged/re-branded tons of times. You mostly need to know the type of engine that you have and the body style to get parts. From what I can see, it looks like you've got the 139QMB 4T engine. That one is the most common these days and parts are usually pretty easy to find. Check out chassis # 6 here : www.scrappydogscooters.com/CHASSIS_PARTS.html I've got a similar problem. Took a while but I figured out exactly what my scooter is. Only problem is the site you linked does that seem to have a body style similar to mine. I have a 2011 qingqi fizz. All the plastic is rough and the light lenses could use replacing too. Is it possible to strip all the plastics off and choose from one of those types as long as I change the head and tail lights assemblys?
Post by 90GTVert on Feb 11, 2017 13:50:51 GMT -5
I've got a similar problem. Took a while but I figured out exactly what my scooter is. Only problem is the site you linked does that seem to have a body style similar to mine. I have a 2011 qingqi fizz. All the plastic is rough and the light lenses could use replacing too. Is it possible to strip all the plastics off and choose from one of those types as long as I change the head and tail lights assemblys? The mounts would be different so it would be quite a task. Not all panels will fit all frames either. I'd sooner figure out a naked configuration with aftermarket lights (that outperform and outlast the stock stuff).
wk360
Scoot Junior
Post by wk360 on Feb 11, 2017 18:57:10 GMT -5
actually haven't thought about that. Just figured it wouldn't look right with exposed wiring. Any ideas on hiding them?
Post by 90GTVert on Feb 14, 2017 8:20:39 GMT -5
If you have a black frame and put a black covering on the wiring, it's not too bad. My naked scoot has a partial floorboard and a little of the leg shield cut down for a thin center section. Those things make it even easier to make the wiring less noticeable. Mine are by no means hidden, they just blend in a bit. I think the only way you're going to truly hide them on a naked scoot is to find a way to fish them through the frame. That's gonna be more trouble than it's worth for anything short of a show scoot, I'd think. Relocating some accessories to any spots where there are panels or other objects can make it less noticeable too. For example, my turn signal flasher was relocated to just in front of the battery box under the floorboard and my regulator now mounts just behind the seat bucket.
Post by 65cabriolet on Sept 25, 2018 14:45:36 GMT -5
i recently purchased a 49cc chinese scooter for a whoppin $100. only bad thing is i jave no idea what kinda scooter it is and the VIN number only indicated it was built in 2011 its a cixi no make or model. the VIN is LJ5LT8036B1070963. ive sent a few emails to a lady who's email has come up when searching for 2011 cixi scoots. ive enclosed a few pictures: any help would be appreciated. Info from here: www.dmv.org/vehicle-history/vin-decoder.phpDecoded VIN: Additional Error Text: The Model Year decoded for this VIN may be incorrect. If you know the Model year, please enter it and decode again to get more accurate information. Make: CIXI KINGRING MOTORCYCLE CO Manufacturer Name: CIXI KINGRING MOTORCYCLE CO., LTD Model: Pedal Style Model Year: 2011 Plant City: Zonghan Vehicle Type: MOTORCYCLE Plant Country: China Plant Company Name: Branch 1 - Cixi Kingring Motorcycle Co., ltd. Body Class: Motorcycle - Scooter Number of Wheels: 2 Engine Number of Cylinders: 1 Displacement (CC): 50 Displacement (CI): 3.051187204 Displacement (L): 0.050000 Engine Stroke Cycles: 4 Engine Power (KW): 2.2371 Fuel Type - Primary: Gasoline Engine Brake (hp): 3 Cooling Type: Air Other Engine Info: 39mm Other Motorcycle Info: 2 wheel light scooter
Post by fugaziiv on Sept 25, 2018 14:47:45 GMT -5
Shipping body parts is just expensive, there really isn't any way around it unfortunately.
Matt
