Post by thxcuz on Jan 30, 2017 12:51:33 GMT -5
New to me xingyue ita 150 Rust in the cylinder. Can it be removed or do I need a new cylinder?
phatmanxxl
Post by phatmanxxl on Jan 30, 2017 13:25:01 GMT -5
I'd just replace, or go BBK since it has to be replaced anyway.
Post by stoneforth on Jan 31, 2017 2:19:44 GMT -5
A hone would probably cost more than a new cylinder and rings. I'd just replace.
Post by humanshield on Jan 31, 2017 14:14:10 GMT -5
That would need to be bored oversize. Not honed.
+1 for replace
Post by dexameth on Jan 31, 2017 19:48:07 GMT -5
Reassemble, new plug, new oil, new rings... Kick it over and redline it a few times. The new rings will scrape all the mess away and poop it out your exhaust.
Disassemble, replace everything and laugh at what you just did.
Then BBK.
Post by thxcuz on Feb 8, 2017 11:08:50 GMT -5
Here's an update: On another forum tvnacman suggested I soak it in vinegar overnight and rinse it out with baking soda and water. I did that and the results were positive Before After I took it to a machine shop and the honed it for free. The machinist said it should seal with no problem. That's good news considering this is an oddball case and a kit would set me back $90.
Post by bluegoatwoods on Feb 8, 2017 21:07:46 GMT -5
Well, I'll be darned.
That did work out pretty well, didn't it?
Post by thxcuz on Feb 8, 2017 21:56:56 GMT -5
Well, I'll be darned. That did work out pretty well, didn't it? I'm as suprised as you are
Post by FrankenMech on Feb 12, 2017 15:59:56 GMT -5
great news!
Aluminum foil soaked in vinegar and rubbed over the surface will remove surface rust real quick. Soaking is not required. Just clean up afterward with soap and water. On a cylinder like that a little glaze breaker or hone action will make it like new. Even a few rust pits will be OK.
Post by thxcuz on Feb 12, 2017 17:02:41 GMT -5
great news! Aluminum foil soaked in vinegar and rubbed over the surface will remove surface rust real quick. Soaking is not required. Just clean up afterward with soap and water. On a cylinder like that a little glaze breaker or hone action will make it like new. Even a few rust pits will be OK. That's what the machinist said too. I'm looking forward to working on this bike while I'm on vacation this week. (Yes I'm on vacation in February. What's even more strange is that I work in TV and they let me take a week off during sweeps....doesn't say much for my directing skills)
Post by FrankenMech on Feb 12, 2017 20:51:41 GMT -5
Isn't your directing job done by then?
Post by thxcuz on Feb 12, 2017 21:05:09 GMT -5
Isn't your directing job done by then? I direct the newscasts I'm the guy who says things like "standby on camera 6 -Take 6! And "it's not my fault the wrong video aired"
Post by FrankenMech on Feb 12, 2017 21:10:28 GMT -5
We have you to blame for the cameras zooming in on those wardrobe malfunctions. -Great Job!!!
Post by thxcuz on Feb 12, 2017 21:16:02 GMT -5
