Post by kymcotallinn on May 19, 2011 11:57:55 GMT -5
cool nobody does not know. Vario settings only answer I received in other forum, rolls are 8,5g, but springs....
Post by kymcotallinn on May 20, 2011 9:58:25 GMT -5
Hi, I found best spec ever, after testing and some changes: Weights: 8g. Clutch springs: Malossi white Driven face spring: Malossi Yellow. Speeding/acceleration from 0-50km is about 4-5sec. Top speed: not known, as still having drive in process due to new piston and cylinder. Hills speeding up, not losing power. Just keep this post, maybe there is somebody else with same Kymco People problem(s). Thank you for the ideas
Post by 90GTVert on May 20, 2011 12:52:11 GMT -5
Thank you for the update. Sounds like you got it dialed in pretty well.
Post by kymcotallinn on Jun 8, 2011 19:52:02 GMT -5
Hello again, problems problems problems :swear: with spec I had it was fine about 60km. Then again no power, or acceleration. At the moment I have: CDI - free unit. Iridium spark. Weights: 8,5g. Clutch springs: Malossi white Driven face spring/Torgue: Malossi ( 2000rpm ) Red. Compression in the engine is 10atm And on the spido 16 000km I was truying also Malossi Belt, but Kymco People has somekind of special clutch, like with small teeths, and normal belt cannot be used, so still riding with the old one until I will need to change all the clutch just to use Malossi belt. So nice bike :stars: Same old question...if you know factory specs for this scoot? :drool:
Post by Thebatman on Jun 8, 2011 20:31:19 GMT -5
HEllo there, Have you happened to adjust the valves?
Having to change all for the malossi belt doesnt make sense, you shouldn't have to do that. Maybe you looked at a different size belt by mistake?
Post by kymcotallinn on Jun 8, 2011 20:50:28 GMT -5
HEllo there, Have you happened to adjust the valves? Having to change all for the malossi belt doesnt make sense, you shouldn't have to do that. Maybe you looked at a different size belt by mistake? Thank you for the answer, All Malossi...tested. This is my 35th scoot and I see thiskind of s*** first time in my life, just to sell own product. I was looking in the google for the same belt, but there is non. normal belt is like IIIIIIIIII here we have iiiiiii one side is like pressed to fit clutch.
Post by kymcotallinn on Jun 10, 2011 5:52:47 GMT -5
:lol: CDI - free unit. Iridium spark. Weights: 7g. Clutch springs: Malossi white Driven face spring/Torgue: Malossi ( 2000rpm ) Red. Malossi belt ( after Clutsh change ) 0-60km without any delay or rev.
So best perfomance for this scoot.
Post by kymcotallinn on Jun 24, 2011 3:52:30 GMT -5
Post by 90GTVert on Jun 24, 2011 10:06:24 GMT -5
The pipe looks good and sounds good! :thumb: You need to take that rear pulley apart and see what's hung up. Clean everything. make sure you have free movement of the torque driver before reinstalling the contra spring and clutch. Check again to make sure the pulley opens and closes and that the spring is keeping good pressure on the pulley. More info... 49ccscoot.proboards.com/index.cgi?board=transtech&action=display&thread=357Not sure what those wear marks would be from. Could be something to do with the malfunctioning rear pulley, maybe not? Best thing I can tell you is to look over the drive boss and variator faces for any burrs or anything that could rub the belt as well as taking care of the TD as said above.
Post by kymcotallinn on Jun 24, 2011 11:55:08 GMT -5
Thank you for reply and instructions, all is moving very well, but this ring on the clutch... At the moment I have somekind of another clutch without this ring.., as this one didnt work properly with malossi belt.
And those strange markings on the belt...is manufacture making. And as you can see in the video, also clutch has somekind of special ring, where those marked places on the belt are running.
And does anyone know stock/original ( even chinese.. ) size of the boss drive ?
Post by kymcotallinn on Jun 28, 2011 12:45:02 GMT -5
Hi to All, if you thinking to buy Leo Vince excsaust... do not buy it! For Kymco People it does not give anything. Only Chopper sound
Post by kymcotallinn on Jul 10, 2011 18:03:16 GMT -5
got Dr Pulley 5g. rolls... Clutch springs: yellow malossi. Torgue spring: stock ( any chinese) Valve: 84 Perfect, what else can I say. Variator is finally set as it should, unrestricted CDI, Iridium spark plug and slider rolls. Now its more like 125cc Tested it: hill is 45degrees, before 35km/h max, now 45 without a problem. Very fast takeover, end speed is about 65km/h with my 110kg body on it If there is any questions about Kymco People S 50cc, I think finally I know all
Post by 90GTVert on Jul 11, 2011 9:42:34 GMT -5
Good to know we've got a Kymco People expert around now! ;D
Post by kymcotallinn on Jul 12, 2011 2:54:23 GMT -5
Good to know we've got a Kymco People expert around now! ;D :cheers: :scoot:
