Post by kymcotallinn on May 18, 2011 16:58:45 GMT -5
Hi to all from far far land I was looking around the forum, found some answers, but not the main I was looking for, every scooter has its own spec, even if it´s 139QMB or 139QMA, can you please help me out with variomatic spec for Kymco People S 50cc. Starting from vario where you can change rolls, what can be best perfomance ( fast takeover, end speed, no problem when driving up to hill ), then Torque Driver springs, what should be there. At the moment I have 7g rolls, FRONT DRIVE PULLEY yellow big spring and 3small white spings in the Vario. This is my scooter www.youtube.com/user/GalloTopsu?feature=mhee#p/a/u/2/j9MZzeD3XAQPS! Sorry english is not my native language Thank you everyone for answering
Post by Fox on May 18, 2011 18:06:09 GMT -5
Try 5 gram roller weights. It'll make the scooter quicker and climb hills better without sacrificing speed. The engine will rev higher all the time so you will burn a little more gas per mile/kilometer.
Post by kymcotallinn on May 18, 2011 18:21:27 GMT -5
Try 5 gram roller weights. It'll make the scooter quicker and climb hills better without sacrificing speed. The engine will rev higher all the time so you will burn a little more gas per mile/kilometer. Thank you, its rev. already now with 7g rolls, but lets try 5grams
Post by 90GTVert on May 18, 2011 19:38:44 GMT -5
:welcome:
If you have a stiffer contra/torque spring in there already the 5g may be too light, but it's worth a try. If it's better, but a little too many revs, you can try mixing the 5 and 7g rollers to work like 6g for a compromise. Just stagger them.... 5g,7g,5g,7g,5g,7g
Post by kymcotallinn on May 18, 2011 20:13:17 GMT -5
If you have a stiffer contra/torque spring in there already the 5g may be too light, but it's worth a try. If it's better, but a little too many revs, you can try mixing the 5 and 7g rollers to work like 6g for a compromise. Just stagger them.... 5g,7g,5g,7g,5g,7g Thank you, maybe its even better just to add 6g, rolls? I will test and let you know, what are the results. PS! Can anyone write here stock settings of this scooter vario? As the scooter is big an heavy maybe it will run best with original setup?
Post by Fox on May 18, 2011 21:16:12 GMT -5
If you have a stiffer contra/torque spring in there already the 5g may be too light, but it's worth a try. If it's better, but a little too many revs, you can try mixing the 5 and 7g rollers to work like 6g for a compromise. Just stagger them.... 5g,7g,5g,7g,5g,7g Yeah that's a good idea. If the 5 gram weights are too light, then use three of the 5's and three of the 7's and that will equal 6 gram.
Post by 90GTVert on May 18, 2011 21:48:31 GMT -5
Sorry, I've never had the pleasure of dealing with a scoot like yours, but maybe someone knows the stock weight rollers. I know most stock clutch springs engage somewhere around 2000-2500RPM and stock contra springs are quite soft.
Post by Fox on May 18, 2011 22:10:56 GMT -5
Post by kymcotallinn on May 18, 2011 22:22:39 GMT -5
Thank you, it would be nice, but in county where I am is 06.21AM and this number does not work from here, but I will try to send them a e-mail
Post by Fox on May 18, 2011 22:23:47 GMT -5
I'll call 'em tomorrow for you.
Where are you?
Post by kymcotallinn on May 18, 2011 22:29:23 GMT -5
I'll call 'em tomorrow for you. Where are you? Not far from Santa I sent them e-mail But this gives you idea, where I am from: en.wikipedia.org/wiki/Estonia
Post by Fox on May 18, 2011 22:39:26 GMT -5
Post by kymcotallinn on May 18, 2011 22:45:40 GMT -5
Yep you are right 13g is way too much.
Post by Fox on May 18, 2011 23:18:49 GMT -5
Post by kymcotallinn on May 18, 2011 23:44:40 GMT -5
Cool, will look this
